FL Digital Designs CM1 1000rms @ 1ohm $320
My ED nine.1 finally died last week so I swapped in this Digital Designs CM1 for my 2-12w6v2s.
Its a solid amp but to save room im going to switch to the HD JL amps so whoever buys this is going to get a basically brand new amp ive only driven about 12 miles since the install. It will come with the box, manual, and if the bass **** i ordered for it comes in ill throw that in too. I took the amp out this morning so that it does not get any more use.
I can email you some pics if you want of course.
I get a pretty good discount at my friends shop so I got it for 342.39. Ill take 320 plus whatever it costs to ship or someone can come pick it up. Let me know if you can find one cheaper...i couldnt.
As I said though its a great amp so if someone dosent take it in about a week i think my upgrade bug will pass and ill just keep it![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Thanks for looking all! Oh by the way if you email me ill get to you faster rjrios@mail.usf.edu
SPECIFICATIONS
Series C
Input Sensitivity 0.2V - 5V
Preset Subsonic Filter 30Hz
Preset Low Pass Filter 80Hz
Tested Voltage 14.4
Tested THD 0.02%
Model CM1
Cont Power at 4 ohm 350W x 1ch
Cont Power at 2 ohm 650W x 1ch
Cont Power at 1 ohm 1000W x 1ch
Damping Factor >150
Dynamic Power 2000W
Efficiency thru Output 65%
Dimensions - mm 244.5W x 54.3H x 340.0L
Dimensions - inches 9.63W x 2.14H x 13.39L
Signal to Noise >100dB
SPECIFICATIONS
Series C
Tested Voltage 14.4
Tested THD 0.02%
Model CM1
Damping Factor >150
Dynamic Power 2000W
LiLS
61
04-14-07 03:39 PM
