NY Stinger Battery Isolator - $35 shipped
Didn't install, so my loss is your gain. Still brand new.
If you want to install another battery in your car, this
is the brand that you want!!!
Advertised Description:
Stinger SGP32 High Current Relay for Battery Isolation SR200
Stinger 200 Amp Battery Relay Isolator : Ideal for battery isolation, Stinger's high current relays are the most reliable and efficient way to add secondary batteries to your system. Compatible with all types of alternators and charging systems, simply connect these relays to operate when the ignition is turned on. The battery systems remain separate while the ignition is off, preventing system drain. Water resistant black phenolic plastic, 100,000 mechanical cycle life
