NJ FS Mephis Audio Amp and Sub 250 plus shipping
I have a gently used Memphis Audio MCD500 500 watt amp and 1 Memphis Audio MS104 sub woofer
They were working perfect when i took them out of the car. (lease was up)
The amp is missing the little covers on the side. Other than that they are in great shape. A few scratches from storage but nothing that my camera would pic up
here are the specs
Class D Monoblock Subwoofer Amplifier
RMS Power Ratings:
250 watts x 1 chan. @ 4 ohms
500 watts x 1 chan. @ 2 ohms
Compact Aluminum Chassis with Custon Black Pearl Finish
RCA Outputs: 1 Pair
Gold Plated RCA Connectors
Full MOSFET Design
Built-In Fully Variable Low Pass Filter: 50 - 250 Hz
18dB Per Octave Crossover Slope
Built In Fully Variable Sub-Sonic Filter: 20 - 50 Hz
Platinum Finish Wire Connections
Accepts 4 Gauge Power and Ground Wire
Optional Wired Remote Gain Control
Adjustable Input Sensitivity: 200mV - 4V
Dimensions: 12.6" L x 7.6" W x 2.4" H
1-year SonicElectronix.com warranty
10" Single 4 ohm MClass Series Subwoofer
Power Handling:
Peak: 400 watts
RMS: 200 watts
Carbon fiber cone
Double roll polypropylene surround
Dual flat spiders with graduated rolls
Single 4 ohm voice coil
Vented basket and vented spider spacer
Aluminum heatsink
50oz. Magnet
Sensitivity: 86 dB
here are the specs
RMS Power Ratings:
RCA Outputs: 1 Pair
Full MOSFET Design
Power Handling:
Peak: 400 watts
RMS: 200 watts
Carbon fiber cone
Aluminum heatsink
50oz. Magnet
Sensitivity: 86 dB
jtgs400
03-03-08 11:06 AM
nsxsupra
08-18-05 01:03 AM
Kevin
06-07-01 11:41 AM
