HI FS: Incriminator Audio IA20.1 2013 Model
I have a lightly used Incriminator Audio IA20.1v3 2013 model amp for sale. Asking $525 shipped CONUS unless you're in Hawaii. Condition is like new. Not a scratch on it.
Description
The 2013 IA20.1 is the 3rd Generation amplifier that dates back to 2004, this model is the foundation of all other IA Series amplifiers. IA Series amplifiers are size for size, some of the most powerful amplifiers available to car stereo enthusiasts. This versatile amplifier is capable of producing power levels that can be used by both a serious competitor and the hardcore daily driver. The new IA20.1 is also a plug and play unit, which means that internal modification is not necessary to achieve competition level power output and also allows competitors the flexibility of running either a 12V or 16V setup, as its 19 volt stable. These amplifiers also come out of the box with the ability to be linked, or "strapped" together to double the power with one unit acting as the Master and the other the Slave. This model also now comes with Mirror Technology so you can match output and crossover settings from every unit by the Master, with an infinite number of Mirror amps.
Features
Digital Class-D Linkable Mono Block Amplifier
Dual MOS-FET Pulse Width Modulation Power Supply
1 Ohm Stable Topology / 19 Volt Stable
Heavy Duty 3 Oz Copper Layer Double Sided Epoxy PCB
Extremely High Tolerance Electrical Components For Reliability
Proprietary Custom Tooled Heatsink with Onboard PCB Support For Vibration Resistance
High End Silver Tiffany RCA Inputs with Metal Potentiometers
Black Molded Oversized 1/0 Power and Ground Inputs
Advanced Strapping with Mirror Technology
Multi-Layer Bullet Proof Protection Circuit
Remote Bass/Gain with Clipping Indicator
1 Year Limited Warranty
Specifications
Rated Power ( 14.4V at 1% THD )
RMS Power - 2 Ohm Linked : 4800W
RMS Power - 1 Ohm Mono : 2400W
RMS Power - 2 Ohm Mono : 1200W
RMS Power - 4 Ohm Mono : 600W
Low Pass Filter ( 24dB/Oct. ) : 35Hz - 250Hz
Subsonic Filter ( 24dB/Oct. ) : 10Hz - 50Hz
Frequency Response ( +/- 1dB ) : 15Hz - 270Hz
Bass Boost ( 45Hz ) : 0 - 9dB
Input Sensitivity ( Volt +/- 5% ) : 6.0V - 0.2V
Signal / Noise Ratio : 95dB
Dampening Factor ( 1 Ohm ) : 350 +
Operation Mode : Master/Slave/Mirror
Power Efficiency ( 4 Ohm ) : 85%
Fuse Rating ( 14.4V ) : 250A
Fuse Rating ( 14.4V Linked ) : 500A
Power Input Connection : 1/0 Gauge
Operation Voltage : 8.5V - 19.0V
Speaker Output Connection : 8 Gauge
Dimensions ( Inches ) : 7.48 W x 2.24 H x 20.47 L
Dimensions ( Millimeters ) : 190 W x 57 H x 520 L
Product Manual: IA20.1
Description
Features
Specifications
Ku@
12-18-08 05:05 PM
O. L. T.
07-28-04 09:23 PM
