CA FS: ZAPCO C2K-3.0X COMPETITION AMPs
Selling my prized amps out of my show car. These things are practically brand new. If you know quality, you'll know the ZAPCO brand. $600 Price is for BOTH amps. They retail $1500 each, and you can find them for about $900 each brand new. Pm me on here or email me at dafoodangel@gmail.com Here are some of the features.
-Chassis design allows infinite customization options by replacing slide-in trim panels to personalize any installation
-SymbiLink¬トᄁ Balanced Technology provides up to 16 volts of balanced input for the cleanest quietest signal possible
-Pre-clip and output clip indicators to maximize performance settings
-Symmetrical, discrete power amplifier circuitry
-Fuse, short circuit, high temperature, DC offset, and over voltage protection
-Dual color LED for power and protection indications
-25-amp High Current Bi-Polar output devices
-50-amp MOSFET switching devices
-Optically isolated power supply
-Gate Drive Boost maximum power supply efficiency and improves overall performance
-Very high damping for excellent speaker control
-Surface Mount Technology w/1% resistors, precision capacitors and massive ground planes
-High Current design allows 2 ohm loads for use as a bass amp with low Z woofer systems
-Four layer PC board with heavy 2 oz copper
-Variable electronic crossovers (Input & Aux Out)
-Pass-through output
-Sub-sonic filter for speaker protection
-Switch for use as stereo, single L ch. or R ch. bridge
-L+R sum mono for use as a bass amp
-Dual cooling fans allow any mounting position
-665 Watt 2 Channel
-665 Watt 2 Channel
mlee21
01-11-07 03:17 PM
