GA FS: Old School Fosgate AMP and 8'" Kicker Sub
A. Rockford Fosgate Punch 55.2 AMP and Kicker CVT 8 inch 4 ohm sub
B. Used but in good condition. I am the original owner of both
C. $125 for both
D. Items located in Atlanta Georgia
$125 for both shipped
I have owned the amp since new and it has been in 3 different cars, always bridged mono. For the last 3 years I have had it in my daughter's 6th generation Accord Coupe in a small truck box. These old RF amps are bullet proof and should continue to provide years of power. It is a great way to add more bass to your stock system without taking up too much space.
Amp specs (These amps always hit harder than the rated specs):
Dynamic Power Rating 4ohm Mono - 250 Watts
Per Chanel in 2ohm load - 120 Watts
RMS continous rating Mono - 110 Watts
Sub specs:
Single 4 Ohm CompVT (CVT) Subwoofer
Shallow mount subwoofer allows for deep bass with minimum mounting depth
Power Handling:
Peak: 400 watts
RMS: 200 watts
Impedance: Single 4 Ohm
Ribbed Santoprene surround
Stitched surround for enhanced cone-to-surround strength
Extra strong adhesive and stitching prevents the cone from detaching from the surround
Strong spring-loaded terminals
Includes a built-in steel clearance adapter plate, which replaces part of the enclosure wall to allow shallower installations
Ventless pole piece for extreme power handling
Frequency response: 25-350 Hz
Mounting depth: 3-3/8"
I don't post much but have been a part of this community since 1999
C. $125 for both
Sub specs:
Power Handling:
Peak: 400 watts
RMS: 200 watts
Kira X
09-03-12 05:45 PM
questnyc
05-13-10 10:21 PM
is350
12-11-07 12:24 AM
PlanetAudioRX
03-13-02 11:26 AM
