FS:XTANT Sub and Amp
For sale:
1 Xtant X604 Amp: Asking $650
Specifications
Number of Channels 4
Watts per Channel 4 Ohm 4 x 75
Watts per channel 2 Ohm 4 x 150
Bridged Mono at 4 Ohm 2 x 300
Module Ports 4-Accessory
Features
Fully Regulated PWM Power Supply
Complimentary MOSFET Design
Defeatable Balanced Input
Adjustable Input Sensitivity
24dB/Oct Low Pass, High Pass, Bandpass Crossover
RCA Outputs with 24dB/Oct Crossover
Left & Right Independent Gains
Adjustable Noise Gate
Passive Rear Channels
1 Xtant X124 Sub: Asking $175
Specifications
Description: 12"
Impedance: 4 Ohm
Power Handling (RMS): 500 Watts
Frequency Response: 27-150 Hz
Sensitivity: 87.5dB
Magnet Weight: 102 oz.
Mounting depth: 7"
Mounting diameter: 11.0625"
Overall Diameter: 14.75"
Diameter - Flat Side: 12.875"
Voice Coil Diameter: 2.5"
Weight: 20 lbs
Specifications
Features
Specifications
Description: 12"
Impedance: 4 Ohm
Sensitivity: 87.5dB
Mounting depth: 7"
Weight: 20 lbs
another
o yea and the amp is not white, it's a chrome color...the white is just a protective covering that you peel off. It actually looks like this
KayGee
12-31-14 09:39 AM
questnyc
05-13-10 10:21 PM
kokopuffs4
03-08-07 02:56 PM
gmac1337
05-30-06 10:43 PM
