Audio equip forsale
Audio equip forsale
1) Pyramid DC power supply, rated to 35 amps, model PS-36KX, perfect for powering up your car at indoor shows. It was used to power up my car at all the indoor shows.
http://f1.pg.photos.yahoo.com/ph/terrytcl/...104.jpg&.view=t
$60
2) Audiobahn 12" speaker grill, ABG12CQ, includes grills for two speakers. Brand new in packaging.
http://f1.pg.photos.yahoo.com/ph/terrytcl/...120.jpg&.view=t
$10
3) Pair of Audiobahn AW1206T 1100 Watts RMS / 2200 Watts MAX Subwoofers
120 oz Double Stacked Strontium Magnets
Precision Heavy Duty Cast Flame Basket
Aluminum Cone
Dual 2.5" ASV 4 Layer 4 Ohm Voice Coils
For 2, 4 or 8 Ohm Operation
2" PHAT Multi Layered Foam Surround
Freq. Response: 20 Hz - 500 Hz
Efficiency: 96.4 dB
Multi-Connection Lug Lock Terminals
Mounting Depth 6 3/4"; Hole 10 7/8"; Outer Diameter 12 1/2"
http://f1.pg.photos.yahoo.com/ph/terrytcl/...view=t&.hires=t
Mounted, but never hooked up, no boxes $200
4) Pair of AW100T Audiobahn 10" Excursion Chrome Basket Single 4 Ohm 400 Watts RMS Subwoofers
10” Excursion Subwoofer
60 oz. Strontium Magnet
Power Handling: 400 watts R.M.S.
Frequency Response: 29Hz - 1kHz
Efficiency: 92.3 dB
PHAT 2” Foam Surround
Non- Pressed, Non-Transfer Paper Cone
KM3’ Coated for Virtually No Cone Distortion
2” 4-Layer ASV Voice Coil
Single 4 Ohm Operation
Mounting Dimensions: Depth; 5” Hole; 9” Diameter; 10 1/4”
Lug Lock Terminals
$100 for both, brand new in boxes
5) Audiobahn A2201T Class A/B Mosfet 2 X 50 Watts RMS Amplifier
50 x 2 at 4 Ohms Stereo
70 x 2 at 2 Ohms Stereo
140 x 1 at 4 Ohms Mono
Dimensions: 2-3/8" H x 12-3/4" W x 8" D
Class A/B MOSFET Circuitry
PWM MOSFET Power Supply
Double Sided Glass Epoxy Circuit Board
THD: 0.02%
S/N Ratio: >100dB
Frequency Response: 10Hz - 40KHz (+/- 1dB)
Variable 18dB Hi-pass Crossover: 50Hz - 750Hz
Variable 18dB Low-pass Crossover: 30Hz to 120Hz
Bass boost @ 45Hz: 0/18dB
Subsonic Filter: 20Hz to 50Hz
RCA Throughput Connections
3-way Protection Circuitry: Thermal, Short Circuit and Overload; Cooling Fan
Cobalt Blue Illumination
High gloss Chrome Plated Finish
Nickel Plated Block Terminals
Brand New in box $90
6) Audiobahn A8002T Intake Series A/B Mosfet 2 X 400 Watts RMS w/Illuminated Logo Amplifier
200 X 2 at 4 Ohms Stereo
400 x 2 at 2 Ohms Stereo
800 x 1 at 4 Ohms Mono
Dimensions: 1-7/8" H x 9-7/8" W x 11-7/8" D
Semi-double Glass Epoxy Circuit Board
THD: 0.02%
S/N Ratio: >100dB
Variable 18dB Low-pass Crossover: 50Hz to 120Hz
Bass Boost On/Off
High Gloss Chrome Plated Finish
Air Induction Fan Cooled
RCA and Speaker Level Inputs
New, but was mounted, $160
7) Audiobahn A2201Q Class A/B Mosfet 2 X 50 Watts RMS Amplifier
THD: 0.02%
S/N Ratio: >100dB
Brand New in box $80
$60
$10
Aluminum Cone
Efficiency: 96.4 dB
Efficiency: 92.3 dB
Lug Lock Terminals
THD: 0.02%
S/N Ratio: >100dB
THD: 0.02%
S/N Ratio: >100dB
Bass Boost On/Off
THD: 0.02%
S/N Ratio: >100dB
ShadyJC
09-14-10 08:49 PM
BLu_Gs3
05-12-04 03:51 PM
