Turbo Project
Old 01-18-07, 09:44 AM
Curry
Curry's Avatar
Default Turbo Project
Hey guys,
I'm in the process of dropping a custom turbo in the camry (1994 V6 1Mz-FE).
So far I've got the turbo (Garrett T3/T04E .60/.63) and i'm shopping around for other parts. Where do you guys usually get your parts for your setups?
Thanks!
Old 01-18-07, 03:29 PM
Apex84
Apex84's Avatar
You can try titanmotorsports.com
Old 01-18-07, 03:53 PM
Lexmex
Super Moderator
Lexmex's Avatar
If you are going to be running high boost on that Camry, probably should give http://www.ipttrans.com/ a call with regard to your tranny.
Good luck on that project, hopefully I get around to boosting my 1MZFE RX300 this year assuming all of my parts are in place.
Old 01-18-07, 04:14 PM
Curry
Curry's Avatar
Yea I looked into them a while back. For now i'm gonna be running low boost.
thanks for the link apex gonna check that out
Old 01-18-07, 06:28 PM
GSoup
GSoup's Avatar
You can find alot of stuff at www.jegs.com and www.summitracing.com (ie. mandrel piping, silicon hoses, clamps, tranny coolers, gauges,..etc..)
Also check here for turbo parts...
http://vertexnow.com/Welcome-Verocious-Motorsports
http://www.burnsstainless.com
http://www.ssautochrome.com
Old 01-18-07, 06:31 PM
Curry
Curry's Avatar
Nice set carlos, Thanks!
Old 01-19-07, 08:19 AM
GSoup
GSoup's Avatar
I also forgot to mention.. there are also several CL vendors you may want to check out.
http://www.mvpmotorsports.com/merchant/index.shtml
http://www.exactmotorsports.com/
http://www.tmengineering.net
Old 01-19-07, 09:39 AM
1loudLX
1loudLX's Avatar
wait, a camry is going boost before a gs3?
Curry, your car will be the ultimate sleeper on the street! You go boy!
Old 01-19-07, 02:05 PM
Curry
Curry's Avatar
Muahahaha. Turbo is on order. Gonna order intercooler today after I take some more measurements. Going to try to get the battery moved IF it warms up at all next week. Then we're gonna take some test fits and start making the pipes and weld a bracket to hold the turbo in.
Only parts I'm really missing now are fittings and 2 injectors from a 7MGTE engine.
Thanks for the links carlos checkin them out now.
1loud, you should see the condition of the car. Rust spots, mismatched paint, dents, scratches galore, bird **** stains. It really is the ultimate sleeper right now. haha.
Old 01-19-07, 02:36 PM
Rising_Sun
Rising_Sun's Avatar
I have a box of spare turbo parts. Shoot me a PM and lets see what you can use.
Old 01-19-07, 02:50 PM
Curry
Curry's Avatar
Cool, sending PM now.
Old 01-19-07, 02:55 PM
Lexmex
Super Moderator
Lexmex's Avatar
So you are going to mount your turbo where the battery currently is...kind of like Tony the Tiger's Camry?
With my turbo idea, I plan to mount it behind the engine at the juncture of the exhaust manifolds for Banks 1 and 2...right before the main cat, following by some piping back over to an intercooler on the passenger side of the engine...that piping will probably be the biggest PITA.
Old 01-19-07, 03:07 PM
Curry
Curry's Avatar
It will be in the same spot, but my friend who is helping me said that he has another idea so I'm going to check out his sketches and see what he has planned.
Also the intercooler I'm going with has both outlets on the same side rather than one on each side.
Wow yours sounds like the piping will really be a pain. GL with that!
Old 01-19-07, 03:32 PM
Lexmex
Super Moderator
Lexmex's Avatar
My first thought on the intercooler was to put it on the same side, but now I am almost 90% convinced to put it on opposite sides.
One odd idea I had was having an entrance at the top of the intercooler and exit on the right side...I have seen a few intercoolers like that. Then, I would be able to put all the piping on the side where the air box would be (driver's side).
Luckily, labor is cheap down here. My uncle and I are considering doing most of the work and then having a friend who works on turbo vehicles do the tuning.
Old 01-19-07, 05:00 PM
Curry
Curry's Avatar
Yea I know which intercooler you're talking about.
I'm hoping the guy that we're going to is cheap with the labor too. From what my friend has told me he's a very good guy and will definetly hook him up.
Quick Reply: Turbo Project
