Recommend me a shop to install Tein CS plus edfc around NYC!
Thinking about getting the Tein CS with edfc but don't know where I can get it installed. Where do you guys get it installed at?
I have a place that can do the CS but don't know if they know how to install the edfc with it. Is it hard to install the edfc? I don't think they ever did a edfc install before.
Its not that hard. i installed it myself on my old GS4. Just takes time because you have to remove the rear seat and run the wires through the firewall.
you may want to check these out.
https://www.clublexus.com/forums/sho...light=edfc+diy
Don't think I can do the install myself, would like someone to do it for me. Its the edfc thats the problem. If its not for the edfc any shop would be able to install the CS. Can i install the edfc after the CS or would it be more trouble to have it installed at a later date?
Installing the Tein's is mostly outside of the car, the only inside work would be installing and tightening the rear top pillow mounts. All of the EDFC work will be inside the car and it's mostly running the wires under the seat. Go ahead and get your Teins installed and do some research with the links Gsoup gave you above, then wait for warm day and do that install yourself and save yourself some money. You'll be surprised at how easy it is.
SnoopyBQ
07-15-06 01:35 PM
