Mechanic Recommendation in NY
Does anyone have any recommendation on a mechanic shop in the NY area - preferrable Queens to have their GS worked on. I am trying to find a place that will change the spark plugs plus all the 60K service done. I went to the dealer and they said it was going to run up to $1095. Is that the right amount?
Anybody know any good mechanic shops that will do the same job at a cheaper price? Im not looking for a ***** job. Maybe somewhere that will do as good as a job as lexus but not for the over priced amount.
Thanks in advance.
Dave
Thanks in advance.
Dave
You could try my friends shop. They are very experience and one quit being a nissan tech to open the shop. Tell them Travis sent you. If you want give me a call at 917-282-7778 to see what exactly you want to do and I'll get a quote for you.
Tarmac Motorsport
89 Florida St.
Farmingdale NY 11735
Tarmac Motorsport
89 Florida St.
I am looking to get the 60k service done on my car except for the basics : oil change and rotate tires.
Im not sure what 60K service intales. I know the lexus service rep said I would def need to change my spark plugs.
But I would print out what the entire service entails (I'm not sure, but I can't see it being much beside basic maintenance (flush this, flush that, etc), figure out what you can do yourself (this site is a great DIY tutorial - Spark plugs are simple on a 430 though, I did mine in about an hour) and figure out what you would want them to do. Then buy the parts from one of the vendors here and supply them with your own parts.
Edit:
Here is the service list
60,000 Miles or 48 Months
Dealer Service Verification
Date: _____________________
Mileage: _________________
❏ Replace air conditioner filter ❏ Replace engine oil and oil filter
(ES 3002, GS models, LS 430) ❏ Replace spark plugs (GS 300, IS 300)6
❏ Replace brake fluid ❏ Re-torque drive shaft flange bolts
❏ Replace differential oil (IS 3005) ❏ Rotate tires
❏ Replace engine air filter ❏ Road-test vehicle
❏ Replace engine coolant
❏ Inspect the following:
____Ball joints and dust covers ____Exhaust pipes and mountings
____Body (see page 129) ____Fuel lines and connections, fuel
____Brake lines and hoses ____tank band and fuel tank vapor
____Brake linings/drums and brake pads/discs ____vent system hoses
____Differential oil ____Fuel tank cap gasket
____Drive belts ____Rack and pinion assembly
____Drive shaft boots ____Steering linkage and boots
____Engine valves ____Transmission fluid
Additional Maintenance Items for Special Operating Conditions:1
❏ Inspect nuts and bolts on ❏ Replace differential oil7
chassis and body ❏ Replace transmission fluid7
❏ Replace air conditioner filter (IS 300)3
Thanks. I did not get the chance to stop by the shop this past weekend. I will try to stop by this coming weekend if the snow doesn't start pouring in.
Thanks in advance.
Dave
Thanks in advance.
Dave
