sume1 install my bodykit in nj
DIY it's really easy... it should come with instructions... i wouldn't recommend drilling or cutting anything....
if you want to take a ride to philly i'll help you put it on for free or you could buy me lunch.
If you have just the front and sides, its actually quite easy, the back is a bit hard
David, the gfx is the Lexus Ground effect kids (front air damn, side skirts, and rear lip) for the 2nd gen IS from Lexus
Yeah some drilling required, in the front bumper where the lip curves up. Each part of the kit comes with a installation manual, so if you do this sort of things then you should be A-okay
The side is simple clip + screws.
The rear requires the cutting of the bumper around the exhaust pipe area and drilling near the sides I think.
It has drawings on the manual if that's what you mean, also the drilling and cutting don't need to be precise, it's actually very easy as long as your holes are within spec and in the general area. The drilling is to let you put a backing plate in behind the bumper so you can tack a clip through it. The cutting is to remove the bumper exhaust area so the lip has room to fit in the same area.
drilling is not necessary for the front bumper i know that first hand... and from what i understand neither is the rear.... i wouldn't recommend drilling or cutting of any sort in case you decide to change the body kit in the future
