DIY Brake Pads and Rotors Install on '08 IS 350
Old 03-16-12, 12:35 PM
Shahryar
Shahryar's Avatar
Default DIY Brake Pads and Rotors Install on '08 IS 350
My 2008 IS 350 is now a bit over 56k miles and was bought new about 3 years ago. I've been told by the dealer on a few recent visits that I need to change all the brake pads and rotors. I've ordered Centric Premium Rotors and Posi-quiet Metallic pads from Partsgeek and they should be arriving in the next few days.
I've read through the DIY threads for the front brake pads and the rear brakes. I'm feeling comfortable about attempting to do the front pads (and hopefully rotors once I find a good DIY on that), but not the rears.
I was wondering if any other 2IS owners wanted to join. I'm in Burtonsville, MD.
Old 03-16-12, 01:49 PM
Evil Teo
Evil Teo's Avatar
make sure u used up all your rotors, most dealership tells you at the half way point and u still have half the rotors left.
Old 03-16-12, 02:48 PM
Shahryar
Shahryar's Avatar
Thanks for the heads up. I'll try to see if I Can find proper measurement information to look for in the rotors before I pull them off. I also need something to measure them - I think it's called a caliper.
Old 03-16-12, 02:57 PM
BernieIS
BernieIS's Avatar
The rears are very easy to do. the are almost the same as the fronts with the exception of two pins and two springs. Make sure you take a picture of the springs that hold the pins in place before you remove them. This will make putting them back on much easier.
Old 03-16-12, 03:02 PM
Shahryar
Shahryar's Avatar
^ I'm nervous about doing the rears after reading through this thread: https://www.clublexus.com/forums/sus...s-of-pics.html .
Seems a lot of people had problems with the calipers being stuck?
Old 03-19-12, 07:47 AM
Evil Teo
Evil Teo's Avatar
it is quite simple actually. I didn't do the rotors but I changed my rear brake pads. 30 minutes was all it took. we did it on the streets too. lol anyways I had a helping friend so it was easy. im not sure if its a little bit different from an ISF since they are brembos.
Old 03-21-12, 10:56 AM
Shahryar
Shahryar's Avatar
^Yeah I'm not sure. But with the tutorial that I linked to on the rear brakes, everyone for a page or two was getting stuck at one part and I don't want to deal with that.
Hopefully my brakes have arrived and I can start the install soon. I need to find a walkthrough on the 2nd-generation ('08) IS 350 Front rotor install first though.
Old 03-21-12, 12:26 PM
BernieIS
BernieIS's Avatar
If you need help you can hit me up and I will get you my number and I can walk you through it via phone or text.
Old 03-24-12, 05:24 PM
Shahryar
Shahryar's Avatar
^ Wow, thanks so much for the offer man, I appreciate it. Again, I don't think it's that I couldn't follow the instructions. The issue is what I would do if I'm dealing with that caliper issue that everyone's complaining about. That's what I'm nervous about.
Damage
IS F (2008-2014)
27
11-15-11 01:26 PM
nysupraman
NELOC
19
10-20-10 01:53 PM
cupid0210
Suspension and Brakes
10-19-10 11:00 PM
Quick Reply: DIY Brake Pads and Rotors Install on '08 IS 350
