Mechanic help!!!
Mechanic help!!!
I need help guys!!! I have been having a lighting issue in my 06 is350
Changed bulb and ballast and still my driver side headlight low beam goes off..
I need I lexus mechanic that you Guys can recommend in Long Island nassau county
If possible... Thanks Guys I really appreciate any help!!
first off did you go oem with the bulbs and ballast u use to replace the bad parts? Does both sides goes out? Did u try to do the bulb swap method? I don't live around that area so I wouldn't know. I think u will need to seek a car electrician for help.
my suggestion get the garax, maxlux, morimoto bulbs or oem philips
Morimotos
Thanks for the reply I will try new bulbs, originally I try to get garax from ijdmtoys and instead received
Their brand bulbs which I'm having the issues with.. Will try one of the ones you suggested... Thanks for the help
if you bought from ijdmtoys garax I would demand a replacement because you didn't get what you paid for. demand them to send another pair of authentic garax or give you a refund. I know that Ijdmtoys had a bad batch of bulbs that they sold. usually they come in a garax package.
Also remember to keep all your receipts because if they ever have a recall on the bulbs getting burn all the time they can refund that to you!
morimotos are like philips replicas but they are quality bulbs. i have always heard good things about theretrofitsource as well so they stand behind their product. unfortunately i don't use them as they weren't on amazon. i am currently using maxlux and have been happy with those. for $40 bucks they are great!
