Northern California Lexus Club We are the Northern California Lexus Owners' Club.
This forum is sponsored by Exact Motorsports
HID installation
Old 11-11-06, 11:41 AM
SCSJ
SCSJ's Avatar
is this a legit one?
http://sfbay.craigslist.org/eby/pts/232750152.html
Old 11-15-06, 03:57 PM
KilaWombat
KilaWombat's Avatar
Anyone around know how to install it on a 93 LS400? Me and another member would like to install HID's as well. We both have a 93 LS
Because I have the old headlights, I've been told that there may be a glare from the HIDs.
I'm in SF, if anyone can help, that'll be great. How much are the name brand ones and how much for no name brand, any difference between them?
Thanks.
Old 11-15-06, 04:17 PM
cliffud
Former Vendor
cliffud's Avatar
Aight man - I got the info for ya.
With the 93 LS4, you'll need a 9003 HID kit. The 9003 bulb serves a dual function as a low and high beam bulb so if you switch to HID's, you'll lose your high beams.
That being said, many HID bulbs that replace dual purpose halogen bulbs come with a metal shield on the bottom so the light doesn't spread to the reflective areas that are normally reserved for high beams.
I can't speak for the 9003 kit that comes from xenondepot.com kit (philips) but I've seen other kits that come with metal shields to help hide the light and the cutoff is pretty impressive. But you HAVE to get a HID bulb with dimensions that are very very very similar to your halogen bulb.
Here's a comparison of my no-name HID kit bulb compared to a halogen bulb. You see how the filament and the gas pocket are near the same height from the mounting point? That tells you that you will have minimal glare. There may still be glare but nothing like a bulb that is designed poorly. I picked up a philips kit 2 years ago and it produced a lot of glare which is why I swapped them out.
As far as price is concerned, plan on spending anywhere between $370-$400 for a name brand kit. Xenondepot.com, one of our sponsors, offers philips kits for around this price. For the no-name brands, I've seen them go for as low as $160-$170. If you get a no name kit though- make sure it comes with the proper wiring harness. You'll want one that has a fuse and relay wired inline otherwise your electrical system will be powering the ballasts and that can be risky since these bulbs require a ton of power to fire up.
Here's a picture of the wiring harness.
Good luck.
Clifford
Old 11-15-06, 06:16 PM
kissbang
kissbang's Avatar
Yeah, self-install is the best deal! Seriously, it's not that hard. Save some cash and do it yourself.
Old 11-15-06, 07:52 PM
genki
genki's Avatar
Post
Does anyone know a place that have HID kits and can install in San Francisco?
Old 11-27-06, 09:32 PM
Surfrcali
Surfrcali's Avatar
Default What was the cause of the distorted beam pattern?
Originally Posted by gqchynaboy
Yes do it yourself if you can. Aries had a problem with her Xenon Depot HID Kit and it looked like this.
E.M. wanted $85 to take a look at it, I found out the problem and fixed it in 5 minutes and saved her $85.
What ended up being the cause of your beam pattern? And does anyone having trouble fitting the hid bulb in the socket ?
Old 11-27-06, 09:36 PM
Surfrcali
Surfrcali's Avatar
Default is250 hid help!
I have a prob..I installed my Hids and i dont think i have them tottaly secured but it was super hard to get them to fit..anyone else have that trouble..? Also the beam pattern is funky? Help!
Old 11-27-06, 10:59 PM
Aries
Aries's Avatar
Surfrcali.....sent you a pm
Old 11-28-06, 02:17 PM
gqchynaboy
gqchynaboy's Avatar
Cause of the beam is because the bulb was not all the way in the socket. Solution is take off the two rubber o-rings that are on the base. GL
Malcri
Florida Lexus Club
10-24-17 12:28 PM
spiros
Northeast
08-26-14 07:11 AM
stealth99
CL of Southern California
23
01-21-13 06:03 PM
jhbhatia
Lighting
11-29-11 07:28 AM
bagwell
02-03-06 07:19 PM
Quick Reply: HID installation
