Last edit by: IB Advertising
Browse all: Steering and Suspension
- Suspension Modifications
Overview of popular modifications to customize your Lexus
Independent Shops for: 30/60/90k Service, Suspension Mods, Engine mods, etc.
#392
Club Lexus Vendor
![](https://www.clublexus.com/forums/images/ranks/rank-vendor2.gif)
exact is an ok shop. john is a cool guy and sandy is ok but she overprices everything. Also some days they are great and other days they are not so great. i have been going there since, 2000 and well everytime i go back it gets worse. I had a problem with my lx470 suspension and went to him. Well after a test drive with him, he told me that maybe my tires are overinflated
i mean come on im not retarted, if the tires are overinflated i know it ouwl bounce a bit. but my automatic suspension has been acting up. i.e when i am at a stoplight the ride height all of a sudden drops all of sudden and then raises back. Also the car now rides like im on litterly on a horse. NOw after we get back to the shop he takes the car in the shop for like 5 mins and tells me its the tires.
then charges me $150. to take air out of my tires.![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
4/10/09 - THIS IS AN UPDATE FROM POST ABOVE THAT OCCURED ON 3/26/09:
Ok, finally we found the repair order what we had done for your last visit. You brought your car in & complained the car ride stiffness adjustable suspension not working & requested us to test drive & check it, we quote you for an hour labor to diagnostic which is $90 in 12-1-2006. First we brought the car to test drive, we found the car's handling has a little problem. We brougth back to put on the lift to check all the suspension, we found the two front shocks have minor leak, the rest are ok, then we found the tires pressure were too low at 24psi, so we adjusted the tires pressure to 32psi-which is proper pressure for the tires, then we brought the car to test drive again, car handle fine after that. We quoted you $90 before we work on the car & you agreed. After at least an hour to check & test drive, we solved the problem you had complained, and we charged you only $90, not $150. We think it's fair to charge a customer if we solved the problem customer complained about. If you were not happy with our work, you could have come back & we would be happy to take care of you, but why wait more than two years later to complain in the forum?
__________________
Exact Motorsports
907 Hanson Court
Milpitas, CA 95035
(408) 416 - 0061
(408) 263 - 8100
www.exactmotorsports.com
Exact Motorsports
907 Hanson Court
Milpitas, CA 95035
(408) 416 - 0061
(408) 263 - 8100
#393
Well back to what I was saying earlier..Here are the recent records..
I asked him about my brakes and how it screeches and makes noise when I hardly even press on it and when I press down on it. I think the rotors might need to be resurfaced again, but who knows...
"To answer your question about the brakes, I looked at the service records and the front brakes (pads) were replaced and front rotors resurfaced at 60K. The rear brakes (pads) were replaced and rear rotors resurfaced at 75K svc. There should be plenty of life left on both front and rear. Most likely the rotors are dirty and just need to be cleaned with a brake cleaner. Usually if the rotors need resurfaced, you'll feel vibration when you hit the brakes which I don't believe that's the case.
Since 60K, here's a quick summary of the svcs performed on the car:
- 65K (oil change svc - This usually includes topping off various fluids)
- 70K (oil change svc)
- 75K service (same as a typical 15K svc - usually it involves oil change, air filter, misc fluid top off including transmission fluid change and misc part lubrication, tire rotation,..etc.)
- 80K (oil change svc)
- 85K (oil change svc)"
Now what do I need to do for the 90k? Or need to get? Can I get a quote also.
#394
Club Lexus Vendor
__________________
Exact Motorsports
907 Hanson Court
Milpitas, CA 95035
(408) 416 - 0061
(408) 263 - 8100
Exact Motorsports
907 Hanson Court
Milpitas, CA 95035
(408) 416 - 0061
(408) 263 - 8100
#395
retarded is spelled with a "D"... ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
i seriously doubt it has anything to do with the economy ricky... i dont think this guy is giving the full story.. just what he wants us to know to make his pity story more realistic.
#398
LMAO ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
BTW, we want to know the REAL FULL Story~!
ever since I joined CL, I've only heard great stuff about EXACT![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
oh wait, to be honest, I have heard one complaint, and that was because someone took the fake cheap replica kit to them and expected them to make it fit perfectly
#399
Hi, we don't recall that we ever charged a customer $150 jut to take air out from the tires, there must some other work we had done for you that you willing to pay for $150, please give us your full name, we will look up in our record, we will tell you what we did to the car at that time. Thank you.![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
I suggest you PM LX470man and attempt to "Clear the Air" with him.
It is definitely not fair of LX470man to make accusations and when EXACT replies in their own defense, there is no response from him for several days now. I see that LX470man has been posting on the forums several times since then.
LX470man, if you are reading this, you should do the right thing and clarify your statement directly with EXACT about charging you $150 just to take air out of your tires.
#401
oh wait, to be honest, I have heard one complaint, and that was because someone took the fake cheap replica kit to them and expected them to make it fit perfectly![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
I went for the seibon because it had carbon fiber accents, not because it was cheap and fake.
Also seoul, Keep your hypocritical comments to yourself cause you also have a fake,cheap, and replica front and sides
#403
Hey Everyone -
I'm interested in having the F-Sport Springs installed. I know next to nothing about installing this kind of stuff in my ride so I called the Pleasanton dealership. They gave a quote of $778.00 to install and then they recommended a $99.00 alignment on top of that. This is insane in my opinion. That's $877.00 just for installation.
Anyone have any suggestions for installation with a good shop/trusting shop? I'm all about keeping my car in top shape in terms of not having things half *** installed. But this is nuts. Any help or suggestions would be great. I live in the Concord area.
#404
I'm in the same boat as you iceache925. I'm looking to get my F-Sport shocks and springs installed. Called up Pleasanton Lexus and they quoted me for $1080 + alignment. I'm also looking to get the F-Sport exhaust and Sways put on two. They said an extra $500 for those two things. Nearly $1600 for these four things? Wow. Lemme know if you find someone cheaper. I'm calling up KarTunz (down the street from Lexus of P), and Wheel Works tomorrow. I'll let you know what they say. Anyone else have any shop suggestions? Thanks.
__________________
|2008 IS350|Obsidian Black w/ Black Interior|Premium Package|Full GFX Kit|F-Sport Intake|Tint 35% Front 20% Back|OEM iPod Integration Kit|Redouts|Sport Pedals|http://www.cardomain.com/ride/3163612|
__________________
#405
wow those are some crazy price
you can probably do your rear sway and exhaust in your garage if you have the tools
exhaust is only held by two bolts and 4 rubber hangers![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
have you guys contacted EXACT??
