*Wheel Question* Change my offsets
Does anyone know of a Wheel Repair Shop in Nor-Cal that can change the offset of my wheels? I am wanting lower offsets to give me a deeper dish. I have 2pce wheels that are welded. Wanna keep it up here in Nor-Cal so I can drop em off and pick em up....
Northern California Regional Officer
My machinist can probably mill the surface for you but the problem is the lug bolt holes will probably not have enough metal left if you surface the hub area too much. You'll have to measure to assess feasibility to mill off some of the hub. You could have the holes filled and re-drilled. Probably not a great idea though, and def not cheap to fill and drill 20 holes.
^ Thanks Glen... all that does sound expensive. haha
I've check around, but it's all in So Cal. I am hoping to find some wheel specialists up here in Nor Cal. My budget to get my wheels worked on is around $1,000. Hopefully I can find a wheel repair shop or someone up here. Wanna keep it local.
Why you gotta be so difficult John? lol. just get some newer deeper wheels for the back in the end when your getting those messed with its probably going to cost around the same...have you tried calling stockton wheel on fremont?
