Tire Sensor Problem
Tire Sensor Problem
hey, does anyone know if there was a tire sensor recall or anything? I have been having problem with my tire sensor, not sure which tire, but it keeps going on and off. I had each tire's air pressure checked to make sure i didnt have a leak, and everything was right on. I've noticed it usually comes on when it's cold outside. I dont know if maybe when i got my car serviced maybe the mechanics messed something up or what? It's really irritating! Just wanted to see what some of you thought before i took it in the dealership.
Thanx!
Thanx!
Yes. I drove the LFA.
It depends on where the system was initialized.. Lets say all 4 of your tires were at 40psi when initialized. The lower threshold to trigger the light would be around 32psi (8 psi lower than the original pressure). If your tires were then set to 32-34psi.. the light wouldnt come on, but when really cold, pressure drops, and the light comes on...
PS.. you can initialize your system yourself.. the option is in the menu accessed by the three buttons to the left of the steering wheel... scroll through until it says pressure initialize.. then press and hold the center button until it finishes...
and no.. there have been no recalls pertaining to the TPMS system, not sure why you would think there was.
And sometimes the batteries in a TPMS sensor can go bad or there's other issues with the system - otherwise TPMS systems are pretty reliable. Just make sure the tire shop replaces the mounting nut and o-ring on your sensors during tire service.
JohnnyCake
04-29-07 10:12 AM
