Northern California Lexus Club We are the Northern California Lexus Owners' Club.
This forum is sponsored by Exact Motorsports
Wheel alignment recommendations
Old 06-26-13, 02:21 PM
  #61
leinadmiih
leinadmiih's Avatar
Default good places to get allignment in san jose
where are some good places to get an allignment on my lowered gs in san jose?
Old 06-26-13, 03:34 PM
  #62
Mikeyy
Mikeyy's Avatar
Take it to Tire Outlet in San Jose. Talk to Joseph (he's a CL member) his guys does really good alignments, and his machine is flush mount so you dont have to worry about scraping
Old 07-21-13, 05:11 PM
  #63
droolerk9
droolerk9's Avatar
Default Sonic MS
Originally Posted by new.era.13
SonicMS in Mountain View
They are out of business.
Old 07-25-13, 09:04 PM
  #64
Duck05
Duck05's Avatar
They moved to Milpitas....
Old 08-04-13, 01:14 AM
  #65
lbintab
lbintab's Avatar
Any recommendations on an alignment shop that will allow us to adjust the ride height (air with elevel) to get it in spec for longer drives?
Old 09-13-13, 08:09 PM
  #66
RXSF
RXSF's Avatar
has anybody had experience with Roberts Tire and Wheel in SF?
Old 09-17-13, 10:21 AM
  #67
lx470man
lx470man's Avatar
Is it recommended that after you get new tires on, you should drive on them for a while so they can settle in before getting an alignment done? Or is it OK to just get one done right away.
Old 10-21-13, 06:21 PM
  #68
metaleckz
metaleckz's Avatar
Do you guys recommend the shop in San Bruno? They changed my oil but not my filter
Old 10-22-13, 11:51 AM
  #69
RMMGS4
Northern California Regional Officer
RMMGS4's Avatar
What Shop is in San Bruno? I haven't caught any recommendations in that area.
Old 10-22-13, 03:16 PM
  #70
metaleckz
metaleckz's Avatar
its called "the shop"
but i went to limitless motorsports and they recommend this one place neartheir place!
Old 11-30-13, 12:11 PM
  #71
SparksLex
SparksLex's Avatar
I called the tire outlet off 2nd street and there was no Joseph or a guy with a Lexus. Which location is it?
Edit: Never mind, hes at the Alum Rock one.
Old 01-05-14, 11:33 PM
  #72
dangtheheo
dangtheheo's Avatar
Originally Posted by VDMTom
I always go to Auto Innovation for alignment and tires or Speed Element for tires, now relocated in San Jose. Orlando & Steve provides great service when I need stuff done. And Devin at SE takes care of my tire mounting needs - From what I heard, Speed Element should be getting an alignment machine soon..
Since the rear camber of the 3GS isn't exactly really adjustable, Orlando did his best to make sure when the car was on the rack it would be within specs. It was a bit tricky, but he got it done. Can't wait to get the Cusco rear camber kit when I put on the Air Runners.
I have friends that go to Motorsport Techniques in Hayward also for above services with great results, everything from a super slammed 2IS to 370z.. they got it done in a timely matter. These would be my two recommendations for alignment shops.
Auto Innovation is where I take all my cars for alignment and tires. they're the only shop i've seen that lines up the valve stem with the marking on the tires.
Old 01-06-14, 09:46 PM
  #73
3L4jzz31
3L4jzz31's Avatar
Hey guys,
Just got my s13 (DD) aligned at Wheel Works in Livermore, Car is dropped about 3.5 inches from the ground on the front and they had no problem adjusting the camber plates and the rest of the suspension to get it back into factory specs. They also use an IN GROUND alignment rack and I was told that they could get a car as low as 1 inch off the ground on there.
I have some aftermarket suspension pieces on there so it fell under a "performance alignment" but it was $139 for a "performance alignment" ( altho i payed a bit less :P) It's less if you're using factory adjustment but idk how much.
Hope this helps!
Old 02-10-14, 10:57 AM
  #74
scottkroug
scottkroug's Avatar
If you are really serious about a custom alignment done right. Both of these shops are very good.
Custom alignment http://www.customalignment.com/
Custom Alignment Balance and Brakes
2599 Wyandotte Street, Unit A
Mountain View, CA 94043
California Wheel
http://www.caliwheels.com/
2250 Winchester Blvd., Campbell CA 95008
41 South Capitol Avenue San Jose, CA 95127
I have had both of my Corvette's done at both places. Custom alignment has great techs that really know how to set up a suspension for either road course or autocross.
I take my Z06 to California Wheel in Campbell because it is conveniently on my way to and from work..
Old 02-20-14, 10:42 PM
  #75
nitrotang
nitrotang's Avatar
Anyone use Tech3 for an alignment before? http://www.yelp.com/biz/tech3-auto-r...uery:alignment
Quick Reply: Wheel alignment recommendations
