Time to get ready for the pursuit 3 (caravan info)
#61
![](https://www.clublexus.com/forums/attachments/is-first-generation/45680d1076752890-painters-blue-tape-for-road-trips-111-1106_img.jpg)
^ old pics of Glen's IS
Few blue tape questions . . .
1. how many rolls do you need and what size?
2. how many layers do you need? 1 or 2? 3?
3. tape shouldn't ruin wax or anything right?
4. what happens if it rains, does the tape hold?
5. how long does it take to tape everything up on average?
6. and tape top down right with overlaps between each pass?
#64
No clear bra at this point so Blue tape was a must for Hwy 5.
Ans. 1 roll should be enough for the round trip. 1 1/2" wide not too narrow not too wide.
Ans. 1
Ans. That's why you use Blue tape; standard white tape would be trouble.
Ans. Should be fine
Ans. The more time the neater the job. It pays to be neat as the tape will have less tendency to peel off in the wind. 30 min
6. and tape top down right with overlaps between each pass?[/
Ans. Go from top to bottom. Never bottom up. Always overlap a bit. Try to tape straight without curving to prevent wrinkles.
Even with clear bra, the tape job can be worth it since it is a lot more work to clear off bug splat then to remove the tape. Rock chip prevention is just an added benefit.
#65
^ Thanks Glen ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
The more I've been thinking about tape the more I'm curious what the entire car would look like taped up. Dont be shocked if I show up at the next meet all taped up, just to be different
#67
#68
gemini1
CL of Southern California
09-28-09 01:58 AM
jdmtheory
33
07-13-08 10:14 PM
PhilipMSPT
28
02-18-08 09:20 AM
flipside909
09-13-03 10:28 AM
