3M tape apparently doesn't hold at 130+ MPH
ride was kinda rough since I'm running rubber bands for tires.. but other than that... not bad, pretty smooth... I've been in evo's going 130+ and everything shakes... kinda scary at that speeds
Oh man, I feel your pain KC. I'd hate to have some part get messed up like that on my car. 130mph is fast, but the F can handle more. If you are thinking about putting that thing back on, try polyurethane glue. It's a bit on the permanent side, but I'm sure it won't happen again.
stop using my ideas Brian lol no more giving out my modding secrets lol that does suck though about the lip. did it go through the CF or just the clears and top coat of the resin?
wow, this exact same thing happened to my CF lip about 3 weeks ago. I plan on having the shop paint the middle color match since its where its cracked and leave the splittlers CF. Good luck!
sorry to bump an old thread, but I'll be having a Lexon CF front lip installed in a few weeks and don't want to replicate the OP's experience.... I have a clear bra on the front bumper... will this change what I should do? from the OP's posts, did he use a 3M product that is different from the "automotive" 3M tape???? can/should I glue the lip to my bumper (that has the clear bra on it) as someone else suggested above? (I do track the car and routinely drive 120-130mp on the highway with DD) I'd also like to top the car out some day (170mph +) at the texas mile or something similiar.....
^ i attached the lip over the clear bra... thats why it didnt hold.. plus i didnt clean the surface well enough...my suggestion (from experience) is to use something called 'adhesive primer' if u r going to attach it over the clear bra... clean VERY well with rubbing alcohol before using the primer... this is why I did after my unfortunate event..hasnt come off since.. hope this helps
im sorry but, cmon guys seriously? 3M take on a lip and 130mph.. you cant put all that together and realize that YOU did something wrong? you really thought TAPE was gonna hold? since when? your suposto fasten with screws and brackets..
