Northern California Lexus Club We are the Northern California Lexus Owners' Club.
This forum is sponsored by Exact Motorsports
2jz gte swap
Old 10-18-12, 12:40 PM
grayis250
grayis250's Avatar
Default 2jz gte swap
is anyone here have done this in their is300 ?i need some help about this swap ,it will be helpful if i can take a look at what you have done to your car please.my car is done but it is not running right
thanks guys
Old 10-21-12, 11:51 PM
soarer13oy
soarer13oy's Avatar
Whats wrong with it? I dont have the is but i do have an sc
Old 10-22-12, 11:43 PM
grayis250
grayis250's Avatar
the car started and idle fine but when i rev it pass 4k rpm it will die out ,it cant hold the idle
Old 10-23-12, 12:20 AM
soarer13oy
soarer13oy's Avatar
Have you checked timing? Are you also able to pull codes (jumping the te1 and e11 pins in the diagnostic box)? I recently replaced my gte block with a ge and i was have issues with the car basically bogging around 3.5-4k rpm turned out i was a tooth off.
Old 10-23-12, 10:36 AM
grayis250
grayis250's Avatar
My car is not bogging ,it just can not hold the idle .it will rev freely .can I pull the code even there is no check engine light on
Old 10-23-12, 10:55 AM
grayis250
grayis250's Avatar
I just installed brand new Tps sensor .do you know what the Tps sensor voltage?my car won't start if I set it at 0.60volt
Old 10-23-12, 01:47 PM
KsportUSA
KsportUSA's Avatar
1. Locate TPS wire on ECU
2. Secure your Volt meter to TPS wire + Ground.
3. With car off turn keys to on position
4. Loosen the (2) Phillip screws holding sensor in, sont loosen to much just so it can pivot.
5. Rotate it ever so slightly to you get the reading recommended.
Now your idle should be fixed.
Engine cold between .60-.70 volts DC
Engine warm between .65- .75
Old 10-23-12, 02:41 PM
grayis250
grayis250's Avatar
Unhappy
I did it but car started but will die in a second if I set the Tps at 60 volt dc
QUOTE=KsportUSA;7559402]1. Locate TPS wire on ECU
Engine warm between .65- .75[/QUOTE]
Old 10-23-12, 02:50 PM
soarer13oy
soarer13oy's Avatar
Yes you can pull the codes without them being on. Just jump the pins i told you to. Some codes dont show up unless you jump them. Since you replaced the tps i would assume that is causing your problem.
http://www.supraforums.com/forum/sho...ting-Procedure
Old 10-23-12, 02:54 PM
soarer13oy
soarer13oy's Avatar
If there are any codes: http://mkiv.com/techarticles/engine_...bd1_codes.html
Old 10-23-12, 05:08 PM
grayis250
grayis250's Avatar
Unhappy
Old 10-23-12, 06:11 PM
soarer13oy
soarer13oy's Avatar
were you able to pull any codes?
Old 10-23-12, 07:11 PM
grayis250
grayis250's Avatar
I just got home from work ,how do u full the code
Old 10-23-12, 07:29 PM
soarer13oy
soarer13oy's Avatar
look for the diagnostic box on the engine harness and just the e11 and te1 pins and turn the car to the on position.
Old 10-23-12, 09:50 PM
grayis250
grayis250's Avatar
what is te1 terminal is empty?
Quick Reply: 2jz gte swap
