NX300 Headliner
1st Gear
NX300 Headliner
Just bought a 2019 NX 300 today. I asked them to tighten the rear view mirror because it was loose when adjusting it. I noticed when I got home that the black housing was not tight against the windshield at the bottom. Seems like that slides back up and snaps into place from a video I watched on YouTube, but I also noticed that the headliner is not attached to anything along the windshield and has some play if I push up on it. Is it supposed to be attached and tucked into something where it meets the windshield like it is along the sides? Also noticed a vibration in the passenger side mirror glass.
I have a 2019 also (with factory sliding roof panel), and I think your headliner is normal. The bend in the headliner that runs from side-to-side near the top of the windshield provides sufficient rigidity that front edge support is only necessary in the corners.
If you adjust the passenger-side mirror so one edge of the glass is accessible, does it feel loose when you apply light force (both in-out and tilt) to that edge with a finger?
wildberrie
10-13-12 09:35 PM
turbotuner
06-22-10 08:07 PM
