Air ride question/request
For those of the modders out there that have air bags on their ride, could you tell me how the rears are set up? And maybe if you have a chance take a couple pics of the rear shocks and bags if you get a chance to crawl under your rides? Thanks.
One thing to consider about the data systems controller that I don't think has been discussed would be the speed at which the height adjustments take. I have a 2013 LWB w/ air and was also considering the data systems controller and did a bit of research on it. The OEM air system is not designed to adjust the height immediately as an aftermarket system would allow. While the amount of "time" will vary from car to car, that coupled with the wear and tear on the stock suspension did not seem worth it. For that reason, I gave up on that route and am just saving for an aftermarket suspension setup to replace the OEM one once it inevitably fails.
