2017 NX - Brake Fluid Replacement Interval?
Hi Everyone,
Im in the process of taking my car to my mechanic to change the Front and Rear Pads/Rotors on my vehicle and wondering about if I should also replace the Brake fluid. Car has only 35,000 miles.
Thanks
Thanks
The deterioration of brake fluid is time-dependent, not mileage dependent, and ~6 years is a long time. This is typically a controversial topic, and someone will often report their 20-year old vehicle still has the original fluid and stops just fine
I recommend you read this article, and then decide for yourself. A fluid replacement during brake service should not add more than US$100 to the cost of the job.
Bendix provides an insight into the importance of Brake Fluid - Issue 12 | Bendix Brakes
ACP84 (04-11-23)
I agree with n0v8or. Six years is a long time. I would definitely have it done.
Personally, I only use OEM fluid in my Lexus' brake system.
I drive appx 20-25k/year, mostly highway. Still I purge/fill my brake fluid appx every 2/3 years - depending on my availability. Oh, by the way, I do it myself![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
One of the things I ALSO do BETWEEN those intervals, perhaps a couple times a year, is the following:
With the vehicle cold and on a level surface:
1. Don't keep your reservoir open to air any longer than necessary. As soon as you're done, first thing, close it. Same for your new bottle of fluid.
2. Make sure you close TIGHTLY your bottle of new fluid.
3. I'm not sure of shelf life of brake fluid. Even though it's more expensive to buy the smaller bottles, I DO because I want to use it up ASAP, so as to not have an 'opened' bottle on my shelf too long.
4. I use a glass jar for the old fluid so I can easily see the condition of the old fluid. BEWARE: The visual of the fluid is NOT a conclusive determinant of the effectiveness/condition of the fluid. It may tell you something, but not the whole story.
5. Do your best to NOT get this fluid onto anything, except the rag. It is very strong and can easily eat into your paint and other stuff (i.e. clothing).
- Have a bottle of new fluid handy, in close proximity to the brake fluid reservoir (near master cylinder).
- Place a cloth rag in the area surrounding the reservoir.
- Have a bottle or container available for old fluid, close proximity to reservoir.
- Open the reservoir. Use a turkey baster or Mix Mizer (Walmart ~$3).
- Syphon out a few ounces (perhaps 4) and empty into bottle/container.
- Do this at least a couple times, but not TOO many times. Ensure that you don't completely empty the reservoir, which could let air into the system!
- Replenish the removed fluid with NEW fluid.
- Do this a few times in succession, depending on time, miles and 'how often you brake'. In other words, I would do this N times, until the small (16oz ?) bottle of brake fluid is emptied.
ACP84 (04-13-23)
