Coolant change
Coolant change
My wife's NX coolant is turning acidic at only 50k. I was a bit surprised but tested it twice to verify. I am going to change it next maintence window on both the turbo and the ICE. I have a couple questions one about the coolant and one about repair manual.
Is it okay to use an Airvac tool to fill the coolant on the turbo? I have a CT200h as well and you can only use the airvac on the ICE. The inverter is a lower pressure system and they recommend you do not use a vacuum filler. I want to confirm on the NX airvac can be used on both ICE and Turbo.
