2019 lexus NX300 help with drivers side wire diagram.
Does any body have a picture of how the drivers side bumper wiring harness is supposed to be wired? Thanks for reading! This is on the drivers side. This is the old harness, that was broken on the male end. Part number 8211378190 and i believe this harness is for the front bumper parking sensors This is the female end that was also ordered but need to figure out the orientation of the wires. Here is where the female is supposed to be, but is missing. The part is on the way. Does anybody have a diagram or picture on how the wires are supposed to be oriented? I could figure out where the red, blue, and light blue go, but there are 2 black wires, and a white wire on the female end. And on the male end there are 2 white wires and one black wire, plus the the other 3 wires that are same.
thanks for reading!
Reason: Error in explanation
Refer to the attached drawing.
Your damaged harness-to-harness connector is labeled "AB2".
On one end, there are 2 black wires. Use an ohmmeter to determine which is connected to chassis ground.
On the other end, there are 2 white wires, the proper identification of which will be more difficult. I recommend to trace back to the Radar Sensor connector (located behind the Lexus logo) to determine which connect to Pin 1 and 6 on connector B13.
