NX Electronics Bug - Infotainment Display, Sound, and Lock-up Issues (Merged Thread)
#61
My first (08) RX had a persistent rattle in the sun roof. After many months of trying to fix that, including replacing the cartridge twice and eventually breaking other trim pieces being removed to try to fix the problem, I complained loudly. They told me to bring in the '08 and take a brand new '09. This is the differentiator for me. The '09 has been exceptional and I often wonder why I'm thinking of trading it. Other than some of the tech features, there is absolutely nothing wrong with it.
#62
#64
Nav Screen Garbled
Oh man, as I was exiting the freeway, I saw my nav screen go to this:
I was horrified that thiis might be the nav screen lockup issue where the solution is to replace the console. but I noticed that the screen wasn't locked up as the ungarbled portion was still moving. I pressed the Home button to get into the three screen split view and the nav was the larger half, but the top portion of just the nav window was still garbled.
I then went to make the nav screen full screen, and things went back to normal. Had the car for about a month and a half and this is the first (and hopefully only) time it did this.
#65
#66
If this happens again, You should bring this up to your dealer. Lexus needs to know about the problem and if it is a common problem, they will issue a solution to dealership. Otherwise, at least they can try to trouble shoot it. Plus Lexus dealership service is always known to be great. They really look hard to solve problems.
#67
Might want to post this on the Customer Service forum:
https://www.clublexus.com/forums/lex...r-service-271/
#69
Yes, you should Email it now. Even if it doesn't happen again, have them record it during your next service. That way, if it crops up again (even after your warranty is out), you have something to work with.
This is not the lock up issue.
I've had my system replaced. It's a minor procedure and only takes about an hour.
#72
#73
#74
I have had my vehicle for about a month and 1400 miles and experienced it this past weekend.
I had just got into the car and turned it on. I had Lexus Enform running on my phone. I went to the voice button to try and find a POI. The system froze and a few minutes later rebooted. After the reboot while I was driving I had no issues. I think the reason for me is I was trying to use the system before it had fully turned itself on.
On 2 or 3 occasions I have had the volume adjust itself up from 15-30. I just lowered it a few seconds later. I am sure a new frmware upgrade will come soon.
#75
