Qi charger
#31
I use it quite a lot. My only gripe (other than its location) is that it doesn't regulate the heat. My battery gets up to 119°+.
My QI Chargers at home and at the office senses when the temperature get too hot and slows down the charge until it cools down.
#32
Qi charger removed
I finally got my Qi charger removed by the dealer. They wanted to charge me 2 hours labor to remove it but I complained and they agreed to remove it free of charge. I posted it for sale on ebay if anyone is interested. Not sure how easy the install would be. They claimed they had to remove the center console to get it out but I'm skeptical. I posted pics of the fasteners on the ebay listing.
#33
See that's interesting. My NX just happened to have it, and I have an iPhone. So I ended up grabbing a QI charging case online. It charges my phone fairly rapidly, and never overheats. Whereas my home charging pad seems to get my case hotter than I'd like. I wonder if that's the difference from having the charging element in the phone itself, vs. having it in an external case. More thermal dissipation... I enjoy having the Qi charger, minus the fact I forget my phone in the car about 50% of the time now lol
#34
Do you know what they had to do to remove it. One Lexus service member told me they would have to remove the console to get it out. 2 hours seems like a long time. I need to go back to a dealer and see if a NX without that option has the holes in the console for the tray and it the wiring is there. Thanks for the update
#35
Its out and I'm happy.
I was able to cut the back of the tray and that provided the flexibility to remove it. It turns out the tray is the female part, the posts fixed to the console are around 1/2 inch in diameter and 1/2 inch in length. Out with minimal damage, I could re-install and for the most part hide the cut.
Now according to Lexus I have to hope my wheels don't fall off, or my car burst into flames.
#36
I have an HTC One M8 with metal body. No way to add a module inside the phone because of the metal case. I ordered a DigiYes Ultra Slim Micro USB Wireless Charging Receiver Module ($10 on Amazon.com) and a couple of Qi compatible chargers for home. The adapter is taped to the exterior of the phone and covered by a plastic case protector. At first it worked very well. The Lexus charger was really fast and my home chargers were pretty good as well. However, after about a week I realized that my phone was always very hot when taking it off the chargers, too hot for my comfort level. I did not want to damage the phone so I removed the DigiYes and went back to regular charging. I will make sure my next phone does have built-in Qi charging.
#37
#38
I have an HTC One M8 with a DigiEye ultra slim Qi adapter. At home I have several Qi chargers. After trial and error, the best one I found is the Seneo 3 coils charger stand. It costs Cad$34 on Amazon.ca (probably much cheaper in the USA, as usual!). No problem finding a sweet spot it always works! I even tried with the stand still wrapped in it's bubble wrap and, with this extra space between the phone and the stand, it still worked. The best thing is that it keeps the phone cool during the charge. On the other hand, my phone does not fit the space provided on the Qi charger in the NX! The phone is just a bit too long. There is plenty of space on that charger, why did they make the space so small? It still charges my phone but it also produces way too much heat! I won't be using it, as I don't want to fry my phone, and will be adding a iOttie HLCRIO132 Easy One Touch Wireless Qi Standard Car Mount Charger instead! So much for integrated Qi charging!
#39
Can you provide us with more pictures or videos to show how to remove it? my dealer said they would find out if they remove it for me and would charge me labor to do it.
#42
https://www.amazon.com/Wireless-Nill...qi+car+charger
#43
rather than go thru that, you might want to look at something like this that would kill two birds with one stone (magnetic vent holder/qi charger) - you have the cable hanging around though
Yeah that's the problem. I was trying to achieve a seamless, clean look. No exposed wires at all.
#45
bla bla bla TL;DR -> run cable behind panels for clean look.
