NX - 1st Gen (2015-2021)
Trailer Hitch receiver for the NX300
Old 11-08-16, 01:01 PM
  #31
nickage87
nickage87's Avatar
Here is mine. Got it for ~115$
Old 11-08-16, 01:08 PM
  #32
Kirenworb
Kirenworb's Avatar
The reason I went with the Curt was the max tongue weight is higher than the Draw-tite. (525 vs 350). I have a Curt cargo carrier and it weighs close to 80 lbs so that's a big chunk of the max. If your're pulling a trailer or just have a bicycle rack the Draw-tite is probably better since its more hidden. I didn't care about the hidden part as much.
Old 05-16-17, 07:16 PM
  #33
ReelFish
ReelFish's Avatar
Default Hitch recievers
Hi,
Would anyone have the dimensions or technical drawing for any 1 the following hitches ?
Curt #13214
Curt #12143
Draw-tite #75956
thanks in advance
Old 05-17-17, 09:21 AM
  #34
typocl
typocl's Avatar
google does wonders:
https://assets.curtmfg.com/masterlib..._13214_INS.PDF
https://assets.curtmfg.com/masterlib..._12143_INS.PDF
http://b.cdnbrm.com/images/info/draw_tite/75956.pdf
Old 05-18-17, 02:37 AM
  #35
ReelFish
ReelFish's Avatar
Thanks for your quick reply "typocl", however I already have these.
What I'm looking for are the measurements of the hitches themselves, particularly those highlighted in the attached file.(btw, I did email Curt, but they ain't forthcoming with the measurements)
I'm looking at getting at hitch receiver for my JDM Toyota Harrier 2016 (Xu60 series). There are none available here so I'm looking at getting the hitch shipped from US.
I know the hitches do fit other car makes and models. The closest I found for my vehicle platform is the Lexus NX200t/300h.(hence I'm on this site)
Hope someone could help with providing the measurements so I use it to compare to my car's rear mounting area. The closest match would be the Curt #13214
thanks in advance..
Old 03-19-18, 12:31 PM
  #36
winglesss
winglesss's Avatar
Originally Posted by Kirenworb
I just put a Curt 13214 on mine today. The 13214 I used is the Class III specifically for the NX.
The Curt 13214 hitch is specified for NX years 2015 and 2016.
The Curt 13337 hitch is specified for NX years 2015 through 2018, but the design is totally wrong for my 2017. The mounting holes on my 2017 are on the bottom of the frame rail instead of the side (as-required for the 13214 hitch).
Old 04-14-18, 03:27 PM
  #37
happydoggy
happydoggy's Avatar
Why did the Curt 13337 no work for you vehicle? I was considering it for my 2018 NX300 F-Sport. thanks
Old 04-14-18, 05:42 PM
  #38
winglesss
winglesss's Avatar
Welcome to the forum.
Here is my hitch and hitch wiring topic.
This is the Curt 13337 hitch, showing horizontal mounting holes that don't work for the 2017 NX200t.
This is the Draw-Tite 75956 hitch, showing the vertical mounting holes that fit perfectly.
Old 04-17-18, 07:47 AM
  #39
lexus114
lexus114's Avatar
not to be smart here fella`s. but there is no way in hell i am towing anything in a vehicle i cant properly service the transmission on. these sealed units with no dipstick is down right stupid in my opinion....just sayin. plus i dont have the tow package either so...
Old 04-30-19, 04:54 PM
  #40
mkahl2b2
mkahl2b2's Avatar
Trailer wiring for the 2019 NX300. Does anyone know what will fit?
Old 05-06-19, 06:50 AM
  #41
terrybill
terrybill's Avatar
Curt 56268 and some additional info here. As I recall tapping into the taillight wiring plugs was kind of a nasty tight quarters exercise on the right side but it was otherwise pretty straightforward. Having the battery in the rear simplifies things considerably.
Edit: Now I see that just because it's a 300 no longer means it's a "H" so if yours is not a hybrid and you want lights when the ignition is off (rear power plug is ignition on only) then you're beyond my experience. Good luck!
Old 01-13-24, 01:35 AM
  #42
druster29
1st Gear
druster29's Avatar
Default Uk
Hi - anyone here from the UK who knows where I can buy a hitch receiver (us style)?
wes77
RX - 3rd Gen (2010-2015)
119
03-10-20 08:56 AM
Mysta
05-30-17 07:45 AM
hs250
HS 250h Model (2010-2012)
02-16-10 02:15 PM
accelerate
08-01-06 12:23 PM
jaymoney
RX - 1st Gen (1999-2003)
05-22-06 07:59 AM
Quick Reply: Trailer Hitch receiver for the NX300
