Does Anyone Know Details about the Sound System?
So I have searched high and low for details on the NX Audio System...
All I can find is that there are 2 US versions and a ML version (not sold in the US).
The ML system is highly advertised and full of info( if I had this then I probably wouldnt even consider an upgrade).
The 8 and 10 speaker Pioneer systems have almost nothing. Other than the number of speakers and channels on the amplifier. There is no info on how many watts produced or what load (ohms) the speakers are providing.
Has anyone taken a look to see the power on each speaker?
Which speakers are wired in series/parallel?
The load (ohms) each speaker is putting on the amp?
Are they weird loads like 3, 6 or 8ohm etc. or are they more typical 2 and 4ohm loads. I am hopping the latter so one can just drop in after market replacements with out messing with the amplifier. I just want a little better quality not looking to do an overhaul.
if no one has checked or done an upgrade then it looks like I will be doing a write up on the Audo System when I take delivery on mine
bookmarking this thread!
Someone really needs to do this!
I'm pretty sure the Lexus sound system and mark levinson isn't going to be as good as your aftermarket stuff. Also, is it true that the sub is located on the drunk door?
One more thing, if a person gets an aftermarket in dash, will their lexus enform stop working as well?
if this can help you
http://lexus-nx-club.ru/viewtopic.php?id=224&p=5
i will "open" my lexus soon , i have the 8 speakers Pioneer in
and located in the same place as the ML amplifier
take a look at this
https://partsouq.com/es/catalog/genu...d=4&uid=174719
ramses974, I have had powered Bazooka Tubes in other cars and really like them. They are compact and really easy to install. https://www.southernaudioservices.com/Tubes.aspx
You can add one and if that is not enough bass, you can daisychain a passive tube off of the amplified one.
i saw one guy with the ML in his car , and he was changing all the system , if i have the chance to meet him again i will contact him to post here
IS350Shawn
05-23-13 07:00 PM
iron_lungs
01-28-09 08:35 AM
