The Unofficial Aftermarket Wheel Thread
#241
[QUOTE=corradoMR2;9731149]
The 22s are 9" wide +40. No problem they will fit and be nearly flush with the fenders like mine which are the same specs as your 22s except mine poke a tiny 2mm more out (+38):
Same for the 20 at 8.5" wide +38mm. These will fit too and be about a quarter inch more tucked in than the 22s.
Either are good, pick the one that suits your tastes/budget. Happy shopping!
hows the ride? Still smooth sailing or rough?
#242
The pursuit of F
[QUOTE=jccaguiat;9731506]99% as smooth with 265/35/22s vs the 18" 60 series tires though I attribute that to the AVS my NX is equipped with which compensates in dampening force. On non-adaptive suspension models (I.e. in the US) you'd notice some harshness but all depends on what you can tolerate. If you want to play it safe on ride comfort, go for the 20s with Yokohama Parada Spec X tires.
#243
[QUOTE=corradoMR2;9731712]
what about mpg? Did it go down drastically? And how accurate is the speedometer after you got your 22s?
#244
https://www.carid.com/helo-wheels/he...-86769416.html
https://www.carid.com/ruff-racing-wh...-52595680.html
these 2 are what catches my eyes. What set of tires would work nice? Or are the recommended there good?
#245
The pursuit of F
[QUOTE=jccaguiat;9732322]
MPGs went down by about 1.5-2 on the 22s and about 1 on the 20s but a lot of that is due to the non-low-rolling-resistance tires and wider contact patch (265 on the 22s, 255 on the 20s) increasing rolling resistance.
For 22s, I currently have the Nexen Roadian HP (265/35/22) and I am happy with them for the price. If you want a smoother ride, quieter, better tire overall, but more expensive, go for the Yokohama Parada Spec X in the same size for 22s or 255/45/20 for the 20s is what I had on my past 20 inch wheels. For research on tires, it's best you check out the reviews and tests on tirerack.com and select the one that best suits your needs based on your budget.
#247
Alright friends, correct me if my setup are wrong... But this is what Im about to order...
https://www.carid.com/ruff-racing-wh...-52595680.html - 22" rims
https://www.carid.com/lexani-tires/l...-16754646.html - 255/30 R22
Now the TPMS, this might sound dumb. but can't I just take the old one and put it in the new set of rims? If not, then would these work? https://www.carid.com/2016-lexus-nx-...199083699.html And do I need to order 4? thanks guys!
#248
#249
The pursuit of F
Yes, you can have a tire mechanic remove the original TPMS set and insert them in your new wheels. No programming needed though the mechanic has to keep track of which sensor was in which wheel location (front left, front right, rear left, rear right) and to put it in that location in the wheel to match. If and when you do eventually rotate the tires, just be aware that the pressure indicated by your car will then not match its location of the wheel.
#254
