The Unofficial Aftermarket Wheel Thread
#31
Hey gang,
found these IS wheels on Kijiji, but I am at work and don't know the NX wheel tire size so can't compare the overall diameter. I am pretty sure that being 17inch wheels, there aren't any tires out there to make this work. Thoughts???
4 x oem 2008 lexus is250 wheels 7.5/10cond
17x8" 60.1mm centre bore
5x114.3 bolt pattern
All 4 centre caps included
4 x oem lexus tpms sensors
4 x 205/50/17 brand new federal himalaya ws2 winter tires
Professionally mounted & balanced
#34
#36
The wheels are something I sadly don't think I can touch given that I got the mudguards. However, when I see the amount of rock nicks and hear the amount of rocks hit them when I drive, I'm happy I got them.
Anyone with mudguards swap wheels yet? I'm looking for a side profile to see how wide you can go without going beyond the guards.
#37
#38
The pursuit of F
I had the mudguards from day one. Setup I have is maxed relative to the mudguards. Anything more aggressive and you're sticking out.
Running 255/45/20 rubber on 20x8.5 +35.
#40
#41
The pursuit of F
I have a caliper so I'll measure and post. Stay tuned!
#43
The pursuit of F
OEM F Sport Wheel Specs including offset
^^^It's a great calc!
So here are the OEM F Sport wheel specs!
18x7.5 +35
It's stamped in the wheel! And reason I know the 35 is the offset because I compared to my IS wheels that I know as a fact that have a 45 and 50 offset and they have the same stamping in the wheel.
18x7.5 +35
#45
I'm just back from the wheel shop and got recommended some crazy specs.
front
19x8.5
255/40/19
rear
19x9.5
275/35/19
does it make sense?
front
19x8.5
255/40/19
rear
19x9.5
275/35/19
does it make sense?
