The Unofficial Aftermarket Wheel Thread
#61
LOL, now you're 5% too tall in diameter (763mm vs 727mm) with 255/55/19 vs 225/60/18 and your center of gravity is almost 1 inch taller posing a safety risk in addition to your odomoter/speedometer reading too slow now. It's recommended you stay within +- 3%, personally under 2% is what I prefer.
Again, for 19", 45-50 series max in the 245-265 range wide tires for the size you're looking for.
I called the shop and I'm going for 255/50/19.
cheers mate
#62
Not too bulky and looks good
#64
im looking for new rims for my lexy. these rims and tires work on nx200t? let me know. thanks.
"A set of 4 slightly used 20x 8.5" Lexani CSS8 wheels and Toyo tires(245/35/20). The tires and rim are 4 months old. I paid $2000 for the set, but I have them priced to sell. The tires came off of a 2010 Infiniti G37 S type sedan. The bolt pattern is 5x114.3. The tires have only 8k miles. The lock nuts and key is included as well. Rims are black with Machine finish face."
#65
The pursuit of F
Rubber is too small at 680 mm overall diameter. Stock is 727 mm (225/60/18). That's over 6% too small relative to stock. You want to stay within 3% of that to minimally impact odometer, speedometer, handling/safety.
Wheels are good 20x8.5 and 5x114.3 but you'll need a hubcentric ring on each wheel to take the size to Lexus' 60.1mm
Good luck.
HI2TX (11-06-20)
The following 2 users liked this post by Nigel-JDMParts:
estoscustom (10-03-23),
HI2TX (11-06-20)
