Without power lift gate
Hello,
I just leased the lexus nx f sport but I will not get it until the end of the month or beginning of May. It has everything I wanted, but did not have a power lift gate for the trunk. My question is, it is heavy to close the trunk lid where I am worried that my fiancé will have problem closing. Is it height adjustable?
Lastly, if it is not too much to ask is it possible to post a video of the trunk opening and closing it manually? Thanks!
The pursuit of F
The manual rear hatch, like the hood, is aluminum for weight savings. To get an idea on weight, check out the CT and add a touch more resistance. Height unfortunately is not adjustable and height to the handle is about 80 inches.
The adjustable height is great. I made the mistake of opening it when in my garage without changing anything and I had to put my hand in the way to not scratch my new car. Changing it so it was one notch lower was perfect. I have about an inch clearance when it stops now.
The pursuit of F
Typocl, I believe you're referring to the power hatch...
Gizmo607, see 3:31 in the review below. It gives you a brief idea of the opening, the two handles, and height.
http://nyti.ms/1ldw8bu
