Gear Shift Problems With NX
Alright is it just my car or do all cars have a problem with the gear shift. I have been noticing a "metallic catch" when I shift the gear from Park to Reverse. Once you reach reverse then it is smoother,
This metallic catch some times severely impedes shifting the gear and I have to struggle to get from Park to Reverse. Some times it is not so bad but it is NEVER smooth.
I took it to the dealer, after driving a Corolla which has the same style of gear shift [and this was smooth] last week. Initially I ignored it because I came from a BMW which has buttons instead of manual shifting of gears so I thought I have to get used to shifting gears with Lexus.
The technician and I also tried a brand new NX in the show room and this also had this funny "metallic catch-restriction" when shifting from Park to Reverse.
So he is going to write it up to Lexus.
Any one else having the same issue?
hi, im having the same problem as well with the oil leakage on the gearbox at the same time. did you solve the issue yet?
