NX - 1st Gen (2015-2021)
2 silly questions
Old 05-23-15, 05:34 PM
kchnew
kchnew's Avatar
Default 2 silly questions
Finally got my new 200t this week with premium package and security features. my 1st Lexus. still on the learning curve of the features. really appreciate for the help on the following 2 questions:
1. the key glove from the dealer has a small elastic belt on the middle of the top, am I supposed to cut them? Otherwise how to insert the key?
2. How to check the door is locked when I have the smart access key in pocket? it seems when I have the key in pocket and stand beside the car, the door is automatically opened.
Thanks a lot!
Old 05-23-15, 07:24 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
Congrats and welcome to the forum.
1.The fabric elastic at the top is there to hold the key in the glove. You should be able to slide the key in the glove at an angle while stretching the elastic to the opposite side.
2. With the key fob in proximity (i.e., in your pocket), to lock the door, slide or tap your finger on the small indentation found on each of the door handles. You will hear the car lock and beep. To unlock, place your hand in the door handle and within a second, the doors unlock. At that moment, pull the handle to open the door.
Old 05-23-15, 07:31 PM
kchnew
kchnew's Avatar
Thanks a lot, corradoMR2!
I have read many of your posts in this forum and all of them are very informative and helpful.
Old 05-23-15, 07:37 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
Thanks. Check out the FAQ above, use the Search, or post your questions or comments and someone will help.
Enjoy your first Lexus and NX!
Old 05-24-15, 03:49 AM
DigMyM35x
DigMyM35x's Avatar
I think I understand you question about checking to make sure the doors locked when touching the handle.
If you pull the handle within a second or two of locking the doors, and the door doesn't open then you locked them. There is an audible beep but I do find myself using this method whenever I have passengers in the car since you don't always know if everyone's door is closed when you go to lock the car.
You will hear a confirmation beep when you lock via touching the door handle but I agree that it's nice to be able to confirm.
Hope that helps!
Old 05-24-15, 07:21 AM
ClaudeNX
ClaudeNX's Avatar
In Canada we dont get key glove, at least I did not get
Old 05-24-15, 04:56 PM
computerwi
computerwi's Avatar
If the doors are not closed when you attempt to lock, you will get a long beep indicating so.
Old 05-26-15, 07:49 AM
tresmith00
tresmith00's Avatar
I used to make the mistake of holding the handle and pressing the lock button with my thumb. nothing would happen cause alot of confusion til I figured out what I was doing wrong. I was probably confusing the mess out of the computer. lol
Old 05-26-15, 08:00 AM
15RC350F
15RC350F's Avatar
I find it interesting that while the rear hatch is closing you cannot lock the car with the door handle touch-points, but you can with the fob.
Gs300maste
03-15-19 04:18 AM
drgrant
08-02-18 01:53 PM
orbis0467
09-03-16 12:27 PM
Insomnia
03-07-10 09:38 PM
Quick Reply: 2 silly questions
