Size of fuse
Size of fuse
I am installing a radar detector and wanted to use a "add a circuit" but I bought one for a mini fuse.. Do we have micro fuses?
I look at it yesterday and those fuses are TINY.
Can someone confirm?
this should work right?
I don't have the NX but if it is consistent with recent Lexus and Toyota models, the fuse to be used in NX for the fuse box INSIDE the cabin is probably Mini LP (low profile) fuses. They are very tiny and to pull it out properly, use a quality long nose needle plier if you can't find the plastic fuse puller for Mini LP fuses. (I found one but they are from Japan. I was surprised how difficult to find one in North America)
Either Add-a-circuit fuse taps for Mini or Mini LP fuses should work. If you use the one for Mini LP fuses, the add-a-circuit tap won't protrude as much as the one for Mini fuses. However, in either case, you won't be able to use the existing fuse panel cover to close it.
For your Amazon product listing, that one won't work.
bagwell
02-15-06 10:45 AM
