NX - 1st Gen (2015-2021)
Vibration @ 120 km
Old 11-02-15, 03:23 PM
  #31
NXOwner
NXOwner's Avatar
Location: Driving a UX Hybrid F-Sport! (in So California)
Originally Posted by ho52806
OOOOOOOOh!!!
My bad... Yes, my car has zero vibration at 75mph. You got me on that one NXowner!
ha-ha! I don't even think the NX will go 120 mph!
Old 11-02-15, 04:57 PM
  #32
olgzr
olgzr's Avatar
Originally Posted by NXOwner
You do realize that the OP was referring to 120 kilometres-per-hour and not miles-per-hour, don't you? 120 kph is about 75 mph.
If you did realize that, and if you haven't driven at 75 mph or can't even imagine doing so then, yeah, you're getting old!
LOL, I am old but I do hit 75 mph or more when speed limits allow. I hit 152 mph once, but that was on a race track in a NASCAR race car. That was fun!
Old 11-13-15, 04:56 PM
  #33
ever01
ever01's Avatar
Thumbs down Lexus NX 200T Does Vibrates!!!
Been a loyal Lexus customer for the past 7-8 years. Leased a 2015 Lexus NX 200t SUV in late July, and have taken it to my Lexus dealer to fix a vibration issue. This vibration is felt in the gas pedal, seat, and steering @ 60 MPH or greater. After 5 attempts - I was told that, "the vibrations doesn't substantially impairs the use, safety, or value" and "is a normal characteristic of this particular model."
I was referred by #LexusUSA to the Arbitration body, National Center for Dispute Settlement (NCDS) - who basically rubber stamped Lexus. I was advised by Lemon Law lawyers that this is a typical occurrence.
Please find below, one of the Independent Report from the National Institute for Automotive Service Excellence (ASE); however, I should accept this "feature." Thanks
NX200t! ‪‪#‎Lexus‬ ‪#‎LexusNX‬ #‎Lexus‬ ‪#‎TeamLexus‬ ‪#‎LexusNation‬ ‪#‎LexusLove ‬‪#‎LexusUSA‬ ‪#‎LexusFamily‬ ‪#‎DailyLexus‬ ‪#‎LexusDaily‬ ‪#‎InstaLexus‬ @lexususa
Old 11-13-15, 06:21 PM
  #34
miop4000
miop4000's Avatar
Ok, so what more proof does Lexus need to fix or change your vehicle. You have Lemon Laws in the US. Time to use them.
Not good enough Lexus, not good enough.
Old 11-14-15, 10:07 AM
  #35
tresmith00
tresmith00's Avatar
I just got my tires checked and changed and even though that made difference I still have the vibration in the 70 to 80 mph range.
Now I'm guessing here but after the tire change it's starting to feel like the vibration is coming from the engine not the suspension. I say that because you can usually pin point a tire problem at an exact point in the driving experience. But this particular problem, at least in my car, seems to come on in a range during my driving.
This is a new engine for Toyota/Lexus and it's also their first stab at a turbo engine so it's probably safe to say that this engine may have some kinks.
Old 11-14-15, 11:00 AM
  #36
corradoMR2
The pursuit of F
corradoMR2's Avatar
I have the same minor issue from Day 1, but for me it's at idle around 750-800 rpm which is felt more with the HVAC on. During the drive, engine is still smooth (for a 4 cyl) though...
Old 11-15-15, 04:31 AM
  #37
tresmith00
tresmith00's Avatar
my car idles rough also
The engine maybe a good one but it really lacks the refinement befitting of a Lexus.
Old 11-16-15, 01:00 PM
  #38
Tom59
Tom59's Avatar
Engine won't cause vibrations at 70-80 mph they would be constant if a flywheel was a out of whack.
Drive shafts out of balance do this more than people realize. Also AWD systems one of the shafts might be out of alignment or balance. Ask the dealer to check drive shafts for balancing.
I can tell you as FACT mine doesn't vibrate at all.
..... rotors , shaft balancing, bad wheels or tires. Road Force balancing can find the bad wheel or tire though. Rotors - drive shafts are left. Looks to have two halves and a carrier they can be checked.
AWD or no?
Old 11-17-15, 06:14 PM
  #39
computerwi
computerwi's Avatar
Ditto. I have the same vibration at 750-800 rpm. Completely smooth otherwise.
Old 02-01-16, 08:20 PM
  #40
Dunhill421
Dunhill421's Avatar
Default Reply
Was there ever a solution to your vibration? It's been a few months since you last posted.
Old 06-02-16, 05:17 AM
  #41
Baxter64
Baxter64's Avatar
What is the outcome...? Did this ever get resolved?
I've got a 200T RX fwd Luxury.... same issue.
Vibration at 105kms...worse at 115 to 125kms.... and also has a slight vibration at idle.
All other speeds are fine.
Car is only 3 weeks old... it 'feels' like a drive shaft imbalance...??
Given the mechanicals on the NX 200T are the same, Im keen to hear what happened here.
Old 10-09-16, 03:02 PM
  #42
Dlay138
Dlay138's Avatar
Default 75+ mph isn't smooth ar all
My nx200 AWD, F-sport has the vibration around 75 mph or faster. It seems to get worse when the tires get hotter. How many F-sport owners have a vibration? My local dealer is saying it's common to this model. I think it's the Bridgestone Tires that's on it
Old 10-09-16, 03:09 PM
  #43
LLL1970
LLL1970's Avatar
Default Es300
I can't seem to seat my CV axle. Anyone know what I need to do??
Old 10-09-16, 04:34 PM
  #44
teambell
8th Gear
teambell's Avatar
Default Wrong Forum!
Try this one!
https://www.clublexus.com/forums/es-models-8/
Old 10-09-16, 09:41 PM
  #45
zkl2003
zkl2003's Avatar
Default There is nothing shaking driving 80 MPH
I actually drive 80 Miles a lot on freeway due to a personal habit. I don't notices any vibration at all too. it is also F sport model with Michelin tires.
Quick Reply: Vibration @ 120 km
