💡 Photos of my LED Bulb Replacement in Cargo Area
#62
I thought about it, but was just too lazy. I have some thin adhesive shiny foil for model kits I could have used. Kind of annoyed that the factory didn't metalize the housing part or at least cast it in white.
#64
In the photo further up the thread you'll see a channel in one end of the lens, underneath which is a clip which holds the lens in. I used a wide flat-head screwdriver to depress the clip allowing me to pull that side of the lens out.
#67
#68
My 2016 model uses T10 bulbs. Same as the vanity mirrors. So much easier than these festoon ones as T10 ones are very popular.
I have a question thought. Are the switches supposed to be facing towards the back for both sides? Mine is facing back on the left and on the right, the switch is facing towards the front of the car.
#69
#70
I swear it was on the same side before I changed it.
#71
This is the trend for Lexus to switch all trunk (and also the dome light) from festoon (or called T10 x31 in Japanese reference) to T10. Festoon light bulb is usually brighter than T10 in the same product line.
But the good thing is Lexus has already switched to LED for the dome lights for some. So festoon light is becoming a more specialized type of bulbs (same as reverse light which is T16 if you decide to change it to LED in NX, RX, IS, etc). T10 is more versatile that you can throw in most of the locations inside a car.
#73
But I prefer changeable design as you can upgrade the light bulb (say you find the light not bright enough or prefer different color temperature)
#74
Finally replaced the bulbs in the cargo area over the weekend. The bulbs came slightly longer than the OEM one so I had to bend the metal piece housing a little big to make it fit.
