Will this tire fit this wheel?
Need your expertise.
I have an extra set of rims from an 03 murano, and want to know 1. if these winter tires size will fit into the rims, and 2. Will the rims fit the NX. According to wheel-size.com, these are the wheel specs:
Winter tires: 225/60 18
15 NX:
OEM tire size: 225/60 18
Rim size: 7.5J x 18 ET 35
Bolt pattern: 5x114.3
THD: M12x1.5
CB: 60.1
Diameter: 17"-18"
Width: 7-7.5
Offset (mm): 35
03 Murano
OEM tire size: 235/65 18
Rim size: 7.5J x 18 ET40
Bolt Pattern: 5x114.3
THD: N/A (2010: M12x1.25)
CB: N/A (2010: 66.1)
Diameters : 18"-22"
Width: 7.5-10
Offset(mm): 30-40
I think the rim will fit since the bolt pattern are the same, but I'm not sure if all the other numbers will change that. Please help.
15 NX:
THD: M12x1.5
CB: 60.1
Diameter: 17"-18"
Width: 7-7.5
Offset (mm): 35
03 Murano
Diameters : 18"-22"
Width: 7.5-10
Offset(mm): 30-40
The pursuit of F
Two items are different.
1. The Center Bore is larger so you'll need concentric rings to reduce the 66.1mm to 60.1 mm
2. The 235/65/18 tires are 763mm in diameter versus 727mm for 225/60/18. This means your ride height will be about 18mm higher and both the odometer and speedometer will be about 5% too "slow" (i.e. at 60 mph indicated, you're actually moving 5% faster or about 63mph. Odometer which indicates 1000 miles in reality you've traveled 1050 miles).
Tire will fit in the wheel well but tire experts will not recommend a size discrepancy greater than 3% for safety and speed/odo accuracy discrepancies.
Good luck.
Good luck.
lexlude
RX - 3rd Gen (2010-2015)
04-18-17 11:29 AM
