NX - 1st Gen (2015-2021)
DIY oil change for 2015 NX200t
Old 11-10-20, 10:26 AM
  #76
jsmith
jsmith's Avatar
I found my filter housing drain plug was way over-torqued. I hear that in many dealerships they never take the drain plug off because it's stuck on there once you overtighten it. In fact they use it to take the housing on and off as well. I managed to unscrew the drain plug with a cheater bar and an oil filter grip holding the housing. I looked and i looked until I found a post somewhere that the filter housing drain plug should only be tightened to 10 ft lbs, and that's what I did!
brel523
09-26-21 05:41 AM
sapd911
ES - 6th Gen (2013-2018)
12-12-14 10:00 AM
HS2G
10-11-10 01:36 PM
IS350atWOT
IS F (2008-2014)
08-17-10 01:54 PM
UpstateLex
11-25-09 09:49 AM
Quick Reply: DIY oil change for 2015 NX200t
