NX - 1st Gen (2015-2021)
How to turn off A/C completely?
Old 12-05-15 | 01:34 PM
kchnew's Avatar
kchnew
Default How to turn off A/C completely?
Right now, when I try to get the outside cold air, I have to open the window. Even though I have already turned off the A/C, but the air coming from the outside is still warm after I pushed the "outside air mode" switch. Do I miss anything? Thanks a lot!
Old 12-05-15 | 02:13 PM
corradoMR2's Avatar
corradoMR2
The pursuit of F
Make sure your temp is set to your desired setting. I.e. if you want the coldest available outside air, set the temp to "LO". To do that, you'll need to turn on the ventilation (AC is irrelevant), set temp to LO, turn off the ventilation.
Old 12-05-15 | 02:34 PM
kchnew's Avatar
kchnew
Thanks. So I need to adjust temperature setting to get the outside cold air.
Old 12-07-15 | 07:03 PM
philwojo's Avatar
philwojo
Where is the green light on your panel in this picture, is it on the car on the lower left, or on the one to the right of that, just outside of the image? Just above the hazard button,
To have air flow from the outside the light should be on the one with the arrow moving through the car.
Old 12-08-15 | 09:27 AM
kchnew's Avatar
kchnew
Thanks to philwojo and corradoMR2!
Yes, the button with the air moving through the car is green.
I adjusted the temp to "LO" according to corradoMR2, I got the cold air. Again, thanks.
Chefao
SC- 1st Gen (1992-2000)
02-22-13 10:05 AM
mattham912
IS - 1st Gen (2001-2005)
03-30-09 08:46 PM
Lex08350
ES - 5th Gen (2007-2012)
14
07-15-08 10:47 AM
horent135
07-07-08 11:06 PM
RXGOLD
02-14-05 04:23 PM
