Power Liftgate questions/issues (Merged threads)
#32
This seems to be a common occurence in Toyota Highlanders for years. The Highlanders have a lower trim model that doesn't offer a power liftgate, and someone posted that he replaced the power struts with the manual struts that worked perfectly and saved thousands. I'm not certain if that is an option for the Lexus or not.
#33
Liftgate won't open
NX200 '15- Power lift gate won't open when fob, or dash button depressed. I get one longish beep, no hatch action. I can manually open the hatch from the outside with the handle, and it will unlatch, but not raise more than an inch or two, with the hydraulics keeping it from raising further. Again, one long beep.
I scoured the posts on here, trying the following that was suggested in the various posts on the subject:
Dave
- unlocking all of the doors, and trying trying the lift gate dash and remote buttons
- verifying the power gate setting is "on" in the menu between the gauges, and cycling on and off to be sure.
- verifying the gate height is at "5" in the car settings menu on the center dash display. Cycling through 1 and 5 just to be sure.
- tried locating the elusive "lift gate lock" button on the edge of the glovebox opening, under its lid (there isn't one). Is it elsewhere on this model?
- tried to see if "Valet mode" was somehow defeating it, but it has never been set up, and is confirmed off
Dave
#34
Pop the liftgate with the manual handle outside, then carefully raise it up manually all the way to the top. Try to hit the button to close it, if it doesn't close, then slowly manually push it down and get it to lock. Then try to open it again. When I damaged my sharkfin and had to get it replaced, the hatch was taken off to help with the repair, when I put it back on I had to do this sequence to get the car to automatically raise/lower the lift gate.
#35
Thanks!
Dave
hotnordic (07-19-21)
#38
any luck?
#40
2017 lexus nx rear lift gate noise on closing
Does anybody know what this noise can be? it sounds like something is rubbing/vibrating at the end of the closing.......it only happens 50% of the time.
raynx (07-14-23)
#44
I also have this issue, I tried the silicon suggestion, and it didn't make a difference - any other thoughts or ideas! Mine sounds exactly like the OP's video. Right at the end, although mine is pretty much all the time - at least when it is warmer out.
Attached is my example/video.
#45
