Lexus NX Fijitsu Ten radio Camera pins.
Hi does anyone have any info on what pins are used on the Fijitsu Ten radio in the attached photos. So a reverse camera can be added to the vehicle.
The Lexus NX vehicles with the Fijitsu Ten Radio in South Africa was released without a reverse camera. And i would like to add one to my vehicle.
I need to know the camera Video +( positive) and camera Video – ( negative) as well as the voltage and trigger wires / pins if possible so a reverse camera can be added to the vehicle.
As a worst case i can add a relay from the reverse lights for the power if no 12Vdc is available from the radio.
Thank you in advance.
Hi
you cannot do like that ...
you have to buy a GVIF multimedia interface to do that .
i have the same problem like you and i add a multimedia interface to add the reverse camera. The rear camera mutimedia use the obd 2 code to see when the car is in reverse mode ...
TexLexSC
06-14-17 12:10 PM
BeatSonic
08-10-16 05:38 PM
