NX - 1st Gen (2015-2021)
TPMS Compatibility
Old 04-25-16, 05:27 PM
lexbabe
lexbabe's Avatar
Default TPMS Compatibility
Does anyone know if PMV C010 sensors are compatible with the NX200t? Thanks
Old 04-26-16, 10:51 AM
brook41
brook41's Avatar
I would say no http://dillaircontrols.com/dill/tpms...exus--NX--2016 . Maybe you could contact the seller ? These are used and they have a battery life of 5 yrs so would you chance it ? If you are a member of Costco I found them to be very reasonable @ under $50 to remove and replace a sensor on my 2010 AcuraTL. Tire store wanted over $100 ! Also keep in mind that new sensors have to be programmed.
Old 05-02-16, 08:49 PM
lexbabe
lexbabe's Avatar
Good to know, thanks
Old 05-04-16, 07:05 PM
lexbabe
lexbabe's Avatar
Good news, the above part number is compatible with the NX & most newer Lexus models.
Old 05-04-16, 09:48 PM
stressed
stressed's Avatar
Does it mean that a Quantified value would be displayed in the car?
Old 05-06-16, 09:32 AM
lexbabe
lexbabe's Avatar
Proof in the picture
Old 05-06-16, 01:37 PM
brook41
brook41's Avatar
Great, glad it worked out for you, can you share your experience and any info you have learned. Thank You!
Old 05-06-16, 04:12 PM
stressed
stressed's Avatar
Is there any settings you need to change other then buying those sensors?
corad
06-09-18 03:57 PM
ColdFusion
05-20-18 11:42 PM
STLblueF
IS F (2008-2014)
08-26-17 02:05 PM
Altonymous
GX - 1st Gen (2003-2009)
07-11-15 11:28 AM
Quick Reply: TPMS Compatibility
