be sure to update us on long term use...I'm always wary of these things in case they start rusting after a few months
I've never had any of these pedals that started rusting.
The ones that rust can't be stainless steel (nor aluminum), then—unless they are of the screw type and the screws aren't galvanized or stainless. Maybe the drilled metal OEM pedal would rust if the drilled holes aren't properly primed?
