I used my wife's NX to help jump start my car. When I was removing the cables I accidentally shorted them. I think it blew a fuse for her liftgate, because now it will not function, her car works fine otherwise. Does anyone know which fuse handles the liftgate? I thought I would try replacing the fuse before bringing the car in to the dealer.
Thanks for your help.
Hi, I am having the same issue. How did you end up fixing yours? Thank you
If you are looking for the dedicated 30 Amp Liftgate fuse, it is not in any of the 3 fuse/relay panels. Foe some unknown reason, Lexus mounted it in the power distribution panel that is located above the under-dash fuse panel. It may not be accessible unless part of the lower instrument panel is removed.
In the attached drawing, the liftgate fuse (actually a fusible link) is marked by a red ellipse.
