Bass Produces Rear Door Lift Gate Rattle
Does using the kit behind the plate in the frame fix it or do you still need to put something on the body of the trunk behind the holder to completely get rid of it?
I only did the exterior between the trunk and license plate + frame and as I mentioned, noticeable difference, I would believe if you did the interior side too it would help more, but hard to say to what extent depending on how you interpret sound and the bass notes produced.
This was posted on the Noises, Squeaks and Rattle thread. I was so disappointed when I would hear rattle when I listened to any music. I took my car to the dealer and the technicians were not helpful. They were useless really. After they held my car for a few days and they still couldn't fix the issue I went and fixed it myself.
License plate rattle, https://www.clublexus.com/forums/nx-...ml#post9600276
Subwoofer rattle from inside rear. https://www.clublexus.com/forums/nx-...ml#post9768600
There is a slight rattle still left, but it is barely noticeable. I used to listen to music on BT source and at level 16, whenever a song like Starboy comes on it is horrible. Now I use plugged in source and when Starboy comes on, I can listen at volume 20 and won't hear the horrendous rattle.
2024 update
Thank you for posting this . I was having this issue speaker rattle from the hatch , I take that loose cap off and now no more rattle ,
jeeper2269
11-30-20 09:27 PM
cyprian
06-16-17 05:58 PM
sleffwi
11-10-14 12:41 PM
