Adjustment rear camber
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/image_356054fefd029ed73ae39bcdd6913443bfa1aaa3.jpeg)
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/image_f95bfa331cddaf96354b60dfb87bf011a86e9d61.jpeg)
Hi, I just got my NX200t few weeks ago, but now I Recognize that the rear driver side camber is way to bad. Should I bring it back to dealership for readjustment alignment or is it just a factory common problem so I have to purchase a new aftermarket camber kit?
The rear lower arm is held by an eccentric bolt to the chassis. I was able to have my rear camber zeroed out by having the guys at the shop I went to turn it.
EDIT: BUT since slight camber doesn't cause much tire wear as long as toe is in check, it'd be safer to keep it untouched and have the rear end grip more than the front, unless you do a lot of spirited driving.
![](https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1460/20170627_115216_02_44c25678ae5a76e60be4f603bdb764b8a63895af.jpeg)
This is not a good picture, but it's the only one convenient at the moment. The front wheels are facing square forward and have camber set to -1.3*. You can see rear camber way more upright and zeroed. I have an AWD as well.
But what's with the two big lights on your grill? I'm guessing that if you're not using them to "spotlight" animals, you must be driving in some pretty dark and remote areas.
Sheehan1p
Suspension and Brakes
26
05-29-11 11:54 AM
